Crankcase oil vs Trany oil
  • Roger
    by Roger » Fri Mar 14, 2008 12:03 pm
    My dealer gave me GNA 10w40 motor oil and said to use it in both the crank and trany for my CRF 250R. Is this OK? Would I be better off with a transmission oil? I did not buy my bike there and thought they might be trying to mess my motor up. I hope that is not the case but thought I would ask here.
    by Asmith » Fri Mar 14, 2008 12:31 pm
    It will work just fine.
    It is my opinion that a specialty transmission fluid is more suited to the stress of a gearbox than a typical motor oil.
    I use Maxima MTL 80W in my transmission. Many use the Honda 85W80 (red bottle) in theirs.
  • Cougar1
    by Cougar1 » Thu May 01, 2008 8:58 am
    I did a search to find a thread that already existed. I just bought a 2006 CRF250R used.
    I am an Amsoil guy at heart, but my riding buddy told me to put the Honda HP4 With Moly in the Engine and the Honda HP4 without Moly in the trans. I believe both are 10w40.
    I want to run Amsoil 10w40 in the gearcase side. Do I run that also in the trans? Or Do I need the HP4 without moly? What is recommended that I can buy at the Honda dealer.
    And all I need is an oil filter and the fluids right? Nothing else special?
    Thanks!
    by Skoot22 » Thu May 01, 2008 9:20 am
    Maxima MTL is probably the best oil out there for the Trans. You definitely can feel a difference when the bike shifts. It shifts alot smoother.
  • Cougar1
    by Cougar1 » Thu May 01, 2008 9:47 am
    Alright.. I will try it. So the consensus says 80W?
    Think I can get this at a big motorcycle shop here in town? or special order only?
    by Skoot22 » Thu May 01, 2008 9:48 am
    Cougar1 wrote:Alright.. I will try it. So the consensus says 80W?
    Motorcycle shops should have it. Its not a special oreder item.
    by 124 » Thu May 01, 2008 12:59 pm
    Cougar1 wrote:I did a search to find a thread that already existed. I just bought a 2006 CRF250R used.
    Thanks!
    You can run the Amsoil Motorcycle 10W-40 in both engine and tranny if you want to go that route. These guys will have you doing shots of that Maxima MTL soon if you let them... ;) :lol:
    Kidding aside, Maxima is great stuff but you can't go wrong with Amsoil either. Your choice...
  • Cougar1
    by Cougar1 » Thu May 01, 2008 1:30 pm
    So I was thinking about quantity of fluids. My friend who rides the 450X says to put 1 full quart in the tranny and measure properly for the engine side. So how much do you guys run? Are you all to manual spec or is there a special secret amount?
    And it is ok to run Amsoil 10w40 on both sides without any issues?
    by 124 » Thu May 01, 2008 1:39 pm
    Cougar1 wrote:So I was thinking about quantity of fluids. My friend who rides the 450X says to put 1 full quart in the tranny and measure properly for the engine side. So how much do you guys run? Are you all to manual spec or is there a special secret amount?
    Not sure about running a full quart in the 250R. :-k Can't comment. I usually run about 750-800ml in both sides of my 450R. The 450X absolutely run a full quart in the trans...
    As long as its the motorcycle version of the Amsoil 10W-40; yes, both sides ok.
  • redrooster65
    by redrooster65 » Thu May 01, 2008 3:13 pm
    The full quart is a bit much for the 250's, most guys are running about 800cc's
    by Asmith » Thu May 01, 2008 4:40 pm
    124 wrote: These guys will have you doing shots of that Maxima MTL soon if you let them... ;) :lol:
    Pffft!!! Everyone knows you don't do shots of Maxima MTL...you sip it slowly over two ice cubes... :lol:
  • itsgrady
    by itsgrady » Thu May 01, 2008 6:03 pm
    That stuff is WAAAYYYYY too strong for minors, don't throw those kinda ideas around!
    2009 KX100
    *SST Expansion Chamber
    *Q Silencer
    *Boyesen Rad Valve
    *Acerbis Plastics
    *Monster Energy Graphics Kit
    *2.4 Gallon IMS Tank
    *Kevlar Renthal Grips
    *Tag Bars
    *Boyesen Rad Valve
    by 124 » Fri May 02, 2008 7:18 am
    :lol: :shock:
    crfpwr
    by crfpwr » Tue May 13, 2008 2:44 pm
    so i heard somthing about running atf type f in the tranny side can you do that or is it better to just run the 10w-40 in both....
    why 10w-40? i have been running a 5w-30 is that ok for the hot weather or shall i run a heaver oil
