by 124 » Thu Oct 25, 2007 5:58 am
Ok, ok...let's take a step back.
There are 2 windings in a motorcycle ignition coil. Primary and secondary. The primary side of the coil has many times less "windings" of copper wire than the secondary side. Your primary side has the little wire and the secondary side has the sparkplug wire/cap or alternately called the "high tension lead". They both use a chassis ground to work correctly. That means the metal part of the coil itself is bolted to the frame of the motorcycle. This is what completes the electrical circuit for both the primary side and secondary side of the coil.
So when you measure the primary and secondary sides of the coil, you apply the positive lead of your tester to the end of the wire and the negative lead of the tester to the metal part of the coil WHEN ITS BOLTED ON THE BIKE.
