HELP!
  • Reallysorry0690
    HELP!
    by Reallysorry0690 » Fri Sep 21, 2007 1:02 pm
    im leaking tranny oil out of my head vent hose?
    any ideas?
    Jethro
    by Jethro » Fri Sep 21, 2007 1:22 pm
    is the motor still full on oil. sometimes the crank seal will go bad and pass your motor oil to your trans or rarely the trans to motor. make sure all your vents are clear and not stopped up and check your levels in the trans and motor. if a vent stops up it can sometimes build enough pressure to blow a little oil by where ever it can
