Vanrock wrote:are you sure it isn't at the bottom of the kick when the kick starter hits the foot peg? i always thought something was wrong until i noticed the dint in my kick starter
redindirt wrote:Did the valve check with the valve cover off
I was able to squeeze the .279 mm (.011) under the exhust but it is very tight .. should I re shim the valves ?
redindirt wrote:Vanrock wrote:are you sure it isn't at the bottom of the kick when the kick starter hits the foot peg? i always thought something was wrong until i noticed the dint in my kick starter
He he ,, yes I am sure of that is not the issue..
By the way I pulled the valve cover and had a look at the decompression arm..
It is loose but it is not stuck , I am not sure how it is suppose to work differently then is does now , the knockin sound comes in each turn of the cam when the rocker arm hits the decompression arm and lands on the cam again, but that is just when I turn the engine with the kickstarter , it stops when the engine starts .. You have to excuse my english .
~ wrote:124 wrote:Make sure your decompressor clearance is at spec first. Apply an excessive amount of lube/oil to that area of the decompressor system.
The 250R decompressor is fixed. No adjustments. The picture posted is a 450R.
The weight might be stuck and need lube however.
