Can clutch plates be backwards?
    fbr
    by fbr » Fri Jul 27, 2007 11:47 pm
    I replaced the fiber clutch plates on my son's '07 CRF250R and one of them broke. My wife and son found a "mechanic" that replaced them, again. He is telling us that I installed the fiber plate(s) backwards. This is the fourth CRF250R that I have owned and maintained and I have never seen a reference to installing the fiber clutch plates with one particular side out. I have read that section of the Helm Shop Manual numerous times. Has anyone ever been told this? Am I overlooking this in the Shop Manual? Is there a professional mechanic out there that can distinguish one side from the other?
    Monkeywrench
    by Monkeywrench » Sat Jul 28, 2007 8:47 pm
    Ehh? :-k
    I am unsure how there could possibly be a "backwards" since both sides of the fiber discs have to perform identically! Meaning, doesn't each side of all the fiber discs contact a neighboring steel plate? So then what, I guess it's theoretically possible to install them in backwards, too? Naaaaaa. :roll:
    I guess I can't say for 100% certainty. Just sounds weird is all. I rebuilt the clutch in my 250X this past winter and honestly couldn't tell a difference in upside down/right side up... so I figured it didn't matter. It works just fine.
    2006 450R
    by Aussiecrf230 » Sat Jul 28, 2007 9:59 pm
    We are talking about fiber discs.
    Never heard of this myself.
    If it was an issue you would expect a marking on the fiber plate(generally dye).
    There are different types of plates to make up a clutch pack generally metal and fibre and some clutch packs have a different plate at either end of the stack.
  • Mikey350D
    by Mikey350D » Sun Jul 29, 2007 10:57 am
    A guy who works on my bikes (Pro and great mecahnic)
    installs clutchs as follows:
    Metal (stock) plates are produced by stamping, hence have a sharp edge and a more beveled edge.
    He install plates so beveled edge slides against basket when releasing clutch (I forget which direction this is).
    A little too trivial for me.
    by 124 » Mon Jul 30, 2007 5:45 am
    NO general direction on friction plates...
