Sorry if the title doesn't make a ton of sense, I had to shorten it a bit.
Because I'm a mechanical idiot and can't install a shim correctly, My 06 CRF250R now have a bent valve and a bottom end with some pieces of metal floating around. I plan on fixing the thing, but in the interim I can get a 2004 CRF250R motor for $1155 shipped. The motor will be slightly stripped - no carb, stator, clutch cover or ignition cover, but otherwise together. It is supposed to be mechanically sound and in great running condition.
So, if we pretend that the motor is in great condition, 1) Is that a good price and 2) Will it fit my 2006 carb, exhaust, etc? Thanks in advance, you guys are always great in your advice.
