124 wrote:That's the process. As the valve stem wears at the guide, it allows a small amount of wobble. This wobble creates an incorrect valve to seat angle. The incorrect valve to seat angle creates wear at the contact spot on the valve (and the seat). This wear allows the valve to sit farther into the seat, which in turn closes the valve clearance to the cam. Hence the reason why you put smaller shims to open the clearance back up. Capeesh?
Now that you know there is the incorrect valve clearance, you must shim. Do you have a service manual? If not, get one immediately. Many here at CRF's claim the Haynes/Clymer manuals are very good. I prefer the Honda service manual and can be purchased at www.helminc.com
Now that you have the 1st shim performed, my suggestion is to order some stainless valvetrain replacement parts now. That way when the time comes and you cannot shim any longer, you'll be ready for the overhaul with parts in hand. BTW - I do not recommend using anything smaller than a 130 shim. The valve angle is so thin by then, you increase the risk of sucking a valve and creating much bigger problems.
I posted a basic valvetrain maintenance How-To detailing the steps to replace everything. You may get 6 months from your first shim, but be prepared, your time is ticking. Check the valve clearances more often now.
cromoly wrote:I am in the same boat.. just further down the river... i am at my 130 shim and have stopped riding and am pricing this pending valve job.... Here is the thing and I need assistance... I plan on having this bike for another year befor i upgrade to a 450r... I plan on putting stock valve back into the bike rather than investing in stainless..other than gaskets do I need to have any other parts? IE. can i reuse the springs..ect....
Additionally, the local honda dealer is gonna charge me about $250 for the service plus parts. I can shim this thing with my eyes closed, but have never done valves. Should i attempt it..or pay the $250? IE. is it worth the $250?
FYI.. i dont race, i ride desert trails 2 or 3 times per month and get to the dunes 4 or 5 times a season... the bike does not get what i consider high use where i have it rev'd out and screaming. I bought it used and who knows what the guy before me did...
cromoly wrote:so I orders all of the parts to redo all of the valves, and i found a shop that I can just take the head to and they will swap out all of the valves, cut the seats, ect for like 60 bucks.
When i bought the bike the prevoius owner said the bike had a new piston just put in (he is a friend, so I trust him) My question is what should I look fo in the cylinder or on the piston. There are some deposits on the piston and th cylinder looks clean. The piston has no more that 20-25hrs on it.
The guy at the shop was asking about the power while i was riding, i sad it still pull through all gears and even more than some of my friends older model cr250's which should have more power. He said if that is the case you should be fine.
Long question short what are your thoughts on replacing the piston? (otherthan replace it since i am there.)
