idles but will not rev just backfires pops
  • brownedoff
    by brownedoff » Wed Aug 26, 2015 9:32 am
    Oh i know just to find out if it starves of fuel in around a minuite would mean that the float chamber is not fully filling with fuel ... What does the gasket in between the plates do as I know the bike runs ok for a minuite or two when I stripped the carb then just bogg so I think it sounds more like the old float problem thanks mate ill give it a go on the weekend and let u know thanks for help 😉
  • mossman77
    by mossman77 » Wed Aug 26, 2015 9:41 am
    My guess is that it simply ensures a good seal between the carb and the throttle plate so additional unwanted air can't seep around the edges, which would cause a lean condition (which can cause popping).
    Also check your fuel screw to ensure it is adjusted properly and in good shape (and that the -ring is present).
    2007 CRF250X
    2004 CRF230F (sold)
  • brownedoff
    by brownedoff » Wed Aug 26, 2015 10:20 am
    Ok mate ill try on weekend let u know thankyou
  • brownedoff
    by brownedoff » Wed Aug 26, 2015 10:30 am
    Regarding the fuel screw at the bottom there is only a spring no washer or rubber seal so I have just ordered it hope thats my problem just looked at diagrem and don't know if i lost it or what but would that affect it many thanks big help
  • mossman77
    by mossman77 » Wed Aug 26, 2015 10:49 am
    Uh, yeah. You need those things. That could very well be the ONLY problem. You're sure the washer and o-ring are stuck up inside? They typically don't fall out when you remove the screw. You have to use a pick and pluck them out.
    2007 CRF250X
    2004 CRF230F (sold)
  • brownedoff
    by brownedoff » Wed Aug 26, 2015 10:58 am
    No definetly not in there I can remember blowing the hole out with air line and checking inside with torch to check for and blockages in every orafise thanks as soon as it comes ill try every pointer you have said hopefully rectify the prob and get a good night sleep thanks mossman 😁
  • mossman77
    by mossman77 » Wed Aug 26, 2015 11:39 am
    No problem. Good luck.
    2007 CRF250X
    2004 CRF230F (sold)
  • brownedoff
    by brownedoff » Sat Sep 05, 2015 10:12 am
    Rite I put new seal washer spring on fuel screw no dif tested float ok makes no diff so looked at staor and there was lots of metal filings on the magnet and in the oil filter
  • brownedoff
    by brownedoff » Sat Sep 05, 2015 10:15 am
    So cleaned the stator and magnet put new oil and filter in and started and bike ran better but still bogged if throttle snaped so I'm thinking big engine probs
  • mossman77
    by mossman77 » Tue Sep 08, 2015 7:11 am
    Sounds to me like your main crank bearing is on its way out. This is common on the 250R. Just a guess, but maybe it starts to seize up when you increase the RPMs, which is killing the engine. Are the shavings copper colored?
    2007 CRF250X
    2004 CRF230F (sold)
  • brownedoff
    by brownedoff » Tue Sep 08, 2015 7:31 am
    No it seems to be all silver colour and seems to be steel as it sticks to the magnet what do you think still bearings
  • mossman77
    by mossman77 » Tue Sep 08, 2015 8:47 am
    I don't have an answer for that, but metal shavings aren't a good sign.
    2007 CRF250X
    2004 CRF230F (sold)
  • brownedoff
    by brownedoff » Tue Sep 08, 2015 10:36 am
    Gunna take it to shop in 10 days time for a strip down and rebuild
  • brownedoff
    by brownedoff » Sun Sep 20, 2015 3:20 pm
    Yep had it done bottom top end like brand new now wow
