david53079 wrote:ok got everything back together spot on, and it still wont start. can somebody help me out with some jetting specs, or link me to them, i didnt see exactly what i had on here anywere, i did look. i have a hot cams stage 2 cam, 13.5:1 piston, and full aluminum pro white bros with all stock jetting. i messed with the pilot screw, and got it to start once, but no more after that. elevation is between 250 and 350ft and the temp is anywere between 85-100 when i ride. i looked through my service manual and it says "without mods" also when i push start and do get it going, the off idle is horrible and will even make it die sometimes. if i take it up slow in neutral it will rev to the cieling no problem, if i was a tooth off it would stutter all over the place right?
