2 stroke smoking bad
Posted: Mon Sep 14, 2009 5:45 pm
by jastampke
should there be oil in from the transmission in the crankcase. does all that connect
Re: 2 stroke smoking bad
Posted: Mon Sep 14, 2009 5:56 pm
jastampke wrote:should there be oil in from the transmission in the crankcase. does all that connect
No. The crank seals are bad if that's the case.
Posted: Mon Sep 14, 2009 7:31 pm
by wmrice
I've also seen them leak from bad primary crankcase seals, running it like that is no bueno, depending on how bad it is you could toast your motor, just ask my cousin, he'll tell you from experience. I'd check the crank seals first like ~ said
Posted: Wed Sep 16, 2009 5:26 pm
by jastampke
i took the oil filler cap off while idleing and the rmps surged up and down. so that would mean crank seal right?
