my 06 CR250R Ran away!
    by krisrtch » Sun Jun 29, 2008 8:13 am
    I was riding it around the house to burn the fuel out of the bowl when al of a sudden the engine started running away. TRied the kill switch to no avail. Only way to kill it was to drop it and let the clutch go. Any ideas what would cause it to run away?
    Re: my 06 CR250R Ran away!
    by Asmith » Sun Jun 29, 2008 8:21 am
    krisrtch wrote:I was riding it around the house to burn the fuel out of the bowl when al of a sudden the engine started running away. TRied the kill switch to no avail. Only way to kill it was to drop it and let the clutch go. Any ideas what would cause it to run away?
    Stuck throttle, bad ground on switch...But THE REAL QUESTION is:
    "why are you riding so soon after a collar bone break"???? :evil:
    by krisrtch » Sun Jun 29, 2008 8:26 am
    Well :oops: :oops: I put new graphics on it and when I was puttin the plastics back on I noticed a few what I beleive to be cracks on the pipe and wanted to see if it smoked. So I fired it up and then turned the fuel off to run the bowl dry. the throttle wasn't sticking I'll have to check the ground wire. It didn't hurt to just puut around the yard until I had to drop it. I know I was being stupid. The toys are going up and not coming out until after surgery. I promise. :oops:
    by Asmith » Sun Jun 29, 2008 8:46 am
    Looks great!!!
    Now put it away... :shock:
    by krisrtch » Sun Jun 29, 2008 8:51 am
    It's put put away :( :( :( This sucks not being able to go ride errrr. I actaully can't wait to get this thing plated and get back on them. If I would have been riding her this wouldn't of happened in the first place. The suspension on it is dialed in. The 450 not so much thats what I was doing when this happened.
    woodsman
    by woodsman » Sun Jun 29, 2008 2:20 pm
    Funny you should mention that problem on that bike... The exact same thing happened on a ride with my cousin who has an 01 250. He killed it just as you did, but to fix it he took a stick and wiggled the cable as it goes into the carb. That is what he says he does whenever that happens... Hope this helps. :?
    Currently, 05 450X
    marks crf
    by marks crf » Sun Jul 13, 2008 10:53 pm
    same thing happend to my yAMAHA RT100 i got scarded so i stalled the bike :lol: :lol: :lol: :lol:
    hondafan
    by hondafan » Sun Nov 09, 2008 1:30 am
    Gosh, seeing that 250 all spic and span makes me wish i never sold mine.... NICE BIKE..
    2008 crf 450
    sold-2001 cr250, 2004 crf150, 2003 cr250, 1991 KX80, 2003 TT-R125
    by krisrtch » Sun Nov 09, 2008 5:03 am
    Thank you!
    dlpmx
    by dlpmx » Sun Nov 09, 2008 5:57 am
    My old 2 smokes always did that when the ran out of fuel if I was going slow at the time. My guess would be they just keep leaning out untill run away.
    Dale
    All mods listed in the Garage
  • jt1872001
    by jt1872001 » Sun Nov 09, 2008 10:54 am
    That is what the motor does when running to lean.The internal engine temp is so high that it does not need spark to ignite the fuel, Only compression. so using the kill switch does not work. Next time use the carb drain screw to drain the fuel.
    by krisrtch » Sun Nov 09, 2008 1:16 pm
    Yeah I kinda figured it out when I forgot to turn the gas on @ the track last time I took it out it did the same thing until I turned it on. then ran fine.
    marks crf
    by marks crf » Mon Nov 10, 2008 11:56 am
    it revs hard on 2 stroke lawn mowers when they run out of gas they always go hard when there just about to run out of fuel
    my #00
    5th gear PINNED on the 250
    6th gear PINNED on the 125
