crf250 enduro suspension setup
Posted: Sat Jul 13, 2019 11:58 am
hey everyone, i have some questions about setting up my forks, maybe any of you could help me. my bike is a 2006 crf250r, im 65kg 175cm, i mostly ride enduro, the suspension has stock springs 0.45kg/mm. so my question is what to do to soften the forks? for my weight the bike's suspension feels waaay to stiff, i got the clickers on full soft both rebound and compression. i just opened the forks to change the oil. should i change the mid/base valve stacks? if yes which shims should i remove? or should i go for softer springs maybe?
my shims stacks:
base valve:
11 30mmx0.10mm
1 30x0.10
3 30x0.10
1 25x0.10
1 29x0.10
1 28x0.10
1 27x0.10
1 26x0.10
1 25x0.10
1 24x0.10
1 23x0.10
1 22x0.10
1 21x0.10
1 20x0.10
1 19x0.10
1 18x0.10
SPACER 30,5mmx2mm
1 16x0.20
1 11x0.20
1 12x0.10
1 13x0.10
1 14x0.10
1 15x0.10
10 16x0.10
MID VALVE
REBOUND:
3 16mmx0.30mm
1 11x0.20
1 12x0.10
1 13x0.10
1 14x0.10
1 15x0.10
1 16x0.10
1 12x0.10
1 18x0.10
2 20x0.10
COMPRESSION FLOAT=0,35mm
COMPRESSION:
6 20mmX0.10mm
4 17X0.10
3 10x0.20
my shims stacks:
base valve:
11 30mmx0.10mm
1 30x0.10
3 30x0.10
1 25x0.10
1 29x0.10
1 28x0.10
1 27x0.10
1 26x0.10
1 25x0.10
1 24x0.10
1 23x0.10
1 22x0.10
1 21x0.10
1 20x0.10
1 19x0.10
1 18x0.10
SPACER 30,5mmx2mm
1 16x0.20
1 11x0.20
1 12x0.10
1 13x0.10
1 14x0.10
1 15x0.10
10 16x0.10
MID VALVE
REBOUND:
3 16mmx0.30mm
1 11x0.20
1 12x0.10
1 13x0.10
1 14x0.10
1 15x0.10
1 16x0.10
1 12x0.10
1 18x0.10
2 20x0.10
COMPRESSION:
6 20mmX0.10mm
4 17X0.10
3 10x0.20
