So when I compress my front forks on my crf250x to get the right fork to align before tightening the right side...The fork wants to end up sliding out from hub on the axle and leaving excessive side play. I have all new bearings. Has anyone ever heard of a bent triple clamp? Or any help? thanks!
What it sounds like then , is you do not have the axle in far enough , on the opposite side of the brake , it should be flush with the lug .... OR..... The Speedo Drive is not fully seatedHey Jim,
I am saying there is a gap from side to side wider than it should be. It looks like I would need a wider spacer but this couldn't be because everything is stock?
Hey Jim.
Well so I pulled the axle in to the lug deeper this time and then when I compressed the fork to seat the right side it seemed to work out much better. But I will have to admit...It makes no sense to meI thought that was the purpose of compressing the fork. To align the fork with the other one? But thanks for all your help!
