2003 450 Springs (shock & fork) fit 07?
Posted: Sat May 10, 2014 7:33 pm
by CRFpro982
Long story short I have an 07 CRF450 that I just purchased that has springs set up for 200 pounds and I am 175 pounds. I have a friend sending me stock springs out of a 2003 CRF450 that he says will fit. I am just asking around to verify. Thanks
Posted: Sat May 10, 2014 7:43 pm
by motosicko
02-08 CRF450 Shock and Fork springs are interchangeable.
Posted: Sat May 10, 2014 7:57 pm
by CRFpro982
Awesome news.. Thank you very much!
Posted: Sun May 11, 2014 8:17 am
by CRFpro982
Do I need a special paint if I am going to paint the shock spring?
Posted: Sun May 11, 2014 8:36 am
by Harkon
I would paint the fork spring. Seems a really bad idea.
Or were you talking about the rear shock spring?
Posted: Sun May 11, 2014 8:54 am
by CRFpro982
Harkon wrote:I would paint the fork spring. Seems a really bad idea.
Not the fork springs no one would see those haha.. But yes, the rear shock spring. It is the factory yellow but has a few chips in it.
Posted: Sun May 11, 2014 9:11 am
They are Powder Coated from the factory , so to make the paint really hold up you would need to powder coat it and bake it , with that said , it does not get a lot of direct abuse so you can paint it with a spray can , just (remove it from the shock) scuff it up real good so the paint will stick , and you should be fine
Posted: Sun May 11, 2014 9:39 am
by CRFpro982
JimDirt wrote:They are Powder Coated from the factory , so to make the paint really hold up you would need to powder coat it and bake it , with that said , it does not get a lot of direct abuse so you can paint it with a spray can , just (remove it from the shock) scuff it up real good so the paint will stick , and you should be fine
Thank you very much.. I will give it a shot!
Posted: Sun May 11, 2014 8:28 pm
by Harkon
Aw crap. Sorry, I meant to say I would not paint the fork springs.
That said, the shock spring should be good to paint as JD mentioned.
Posted: Sun May 11, 2014 9:15 pm
by CRFpro982
cool
