2003 450 Springs (shock & fork) fit 07?
  • CRFpro982
    by CRFpro982 » Sat May 10, 2014 7:33 pm
    Long story short I have an 07 CRF450 that I just purchased that has springs set up for 200 pounds and I am 175 pounds. I have a friend sending me stock springs out of a 2003 CRF450 that he says will fit. I am just asking around to verify. Thanks
    motosicko
    by motosicko » Sat May 10, 2014 7:43 pm
    02-08 CRF450 Shock and Fork springs are interchangeable.
    "There are old racers
    and there are bold racers,
  • CRFpro982
    by CRFpro982 » Sat May 10, 2014 7:57 pm
    Awesome news.. Thank you very much!
  • CRFpro982
    by CRFpro982 » Sun May 11, 2014 8:17 am
    Do I need a special paint if I am going to paint the shock spring?
    Harkon
    by Harkon » Sun May 11, 2014 8:36 am
    I would paint the fork spring. Seems a really bad idea.
    Or were you talking about the rear shock spring?
  • CRFpro982
    by CRFpro982 » Sun May 11, 2014 8:54 am
    Harkon wrote:I would paint the fork spring. Seems a really bad idea.
    Not the fork springs no one would see those haha.. But yes, the rear shock spring. It is the factory yellow but has a few chips in it.
    by JimDirt » Sun May 11, 2014 9:11 am
    They are Powder Coated from the factory , so to make the paint really hold up you would need to powder coat it and bake it , with that said , it does not get a lot of direct abuse so you can paint it with a spray can , just (remove it from the shock) scuff it up real good so the paint will stick , and you should be fine
    02 CRF450R
    06 CRF450X
  • CRFpro982
    by CRFpro982 » Sun May 11, 2014 9:39 am
    JimDirt wrote:They are Powder Coated from the factory , so to make the paint really hold up you would need to powder coat it and bake it , with that said , it does not get a lot of direct abuse so you can paint it with a spray can , just (remove it from the shock) scuff it up real good so the paint will stick , and you should be fine
    Thank you very much.. I will give it a shot!
    Harkon
    by Harkon » Sun May 11, 2014 8:28 pm
    Aw crap. Sorry, I meant to say I would not paint the fork springs.
    That said, the shock spring should be good to paint as JD mentioned.
  • CRFpro982
    by CRFpro982 » Sun May 11, 2014 9:15 pm
    cool
