Fork Damper Problems
Posted: Mon May 31, 2010 11:55 am
by speedpeanut
I have an 07 250x, this last weekend I changed the oil and seals. The right side went fine but when I got to the left side I put the fork damper and fork cap back together after bleeding the air. The piston will not fully extend itself like the one on the right side did. I have to pull the piston the last inch. I have added oil and rebleed 4 more times but it is still not extending. Does anyone have some ideas. Is the fork damper bad or the fork cap assembly bad.
Posted: Mon May 31, 2010 12:17 pm
The seal inside the floating piston on the base valve assembly is bad.
Posted: Mon May 31, 2010 2:45 pm
by speedpeanut
The only way that I can find the seal is to replace the entire fork damper. Is it okay to replace just the one or do I need to replace the one in the other fork also?
Posted: Mon May 31, 2010 3:13 pm
Here's the seal:
http://www.crfsonly.com/catalog/product ... ts_id/3237
It's a bear to replace... :shock:
If only the one is bad, replace it. If you figure that if one is bad, the other will be bad soon, replace them both.
Posted: Mon May 31, 2010 3:39 pm
by speedpeanut
Thank you for the link. My service manual does not cover how to replace it. Do you now of any that do?
Posted: Mon May 31, 2010 6:01 pm
by rdz
What I do is buy the cheapest fork damper assembly, part # 51450-MEB-003 ($40.17 from service Honda), remove the entire floating piston from it and install it on to the original assembly. To me its a hell of alot easier than trying to remove and install the seal alone...worth the extra cash in my opinion.
Posted: Mon May 31, 2010 6:25 pm
rdz wrote:What I do is buy the cheapest fork damper assembly, part # 51450-MEB-003 ($40.17 from service Honda), remove the entire floating piston from it and install it on to the original assembly. To me its a hell of alot easier than trying to remove and install the seal alone...worth the extra cash in my opinion.
Not a bad idea... :shock:
It's 4X as expensive as it needs to be, but the aggravation of changing that seal might just be worth the extra $ 30...
