2004 Crf450r suspension setting for crosscountry?
Posted: Sat Sep 12, 2009 11:10 pm
by Sykenmittari
Hello from Finland.
Because CC is much popular in U.S.A.,
i think you guys have found good settings
to stock Crf suspension.(Rebound and compression)
I am only a sunday cruiser so Öhlins isnt the answer.With riding gear on i weight about 203lbs.
Thanks and sorry about my bad english.
T.Syke
Posted: Fri Oct 30, 2009 9:04 am
by Sykenmittari
Anybody?
Posted: Fri Oct 30, 2009 2:48 pm
Stiffer springs front and rear. Your ride gets softer.
Off-road valving is softer than motocross, spring rates are about the same.
Check out Race Techs suspension spring chart, enter your weight, select 'trail ' riding and it'll make a spring rate recommendation.
Install those springs, set the sag, and ride it.
Your owners manual has an outstanding section on adjusting your compression/rebound settings, read it carefully after your initial ride and make any required adjustments.
You'll be very pleasantly suprised. Doug
p.s.
You did just fine !
Posted: Sun Dec 13, 2009 12:16 am
by TRD
Moro!
Laitoin sulle privaviestiä. On täällä muitakin suomalaisia sentäs :)
There is no need for Öhlins. Showa is great ;)
Posted: Sun May 02, 2010 1:14 am
by deathy
Hey just wondering wear I would find this race tech suspension guide, be kind it's my 1st time on the sight
Cheers Andrew
Posted: Sun May 02, 2010 2:42 am
