04 CRF450R SUSPENSION PROBLEMS
  • ALEJO
    by ALEJO » Wed Dec 10, 2008 3:10 pm
    HELP, HELP W/SUSPENSION SETTING ON MY 04 CRF450R PROBLEMS W/FRONT N REAR SUSPENSION CLICKS. I'M ABOUT 165 LBS [/b]
    motosicko
    by motosicko » Wed Dec 10, 2008 3:31 pm
    Your springs may be a little stiff for your weight. Assuming you have correct oil levels and don't have a zillion hrs. on it, Fork comp. should be around 12 clicks , Rebound 10 clicks, from full hard. Shock High speed comp. 2-3 turns out, low speed comp. 12-14 clicks, rebound 8-10 clicks out. These are just my personal tips, the stock settings may vary, start here and adjust to your liking. Make sure your race sag is set-up first. that will tell you if springs are right.
    marks crf
    by marks crf » Wed Dec 10, 2008 5:27 pm
    if u have the money take your forks and shock into a good mx suspension tuner/fixer and get it all setup to your riding style and weight trust me its an good investment to the bike
    my #00
    5th gear PINNED on the 250
    6th gear PINNED on the 125
