450X Springs
    Eric Mac
    450X Springs
    by Eric Mac » Tue Feb 13, 2007 9:25 pm
    Could someone shed some light on the stock springs that are on my 05 450X?
    I just bought a new rear spring and cant decide if I should also replace the front.
    If the stocker is pretty close to what I need for my 6'3" 210lb frame, than I will probably just add some extra oil.
    I have read that it is set up for a 160lb rider and I have also read that it is set up for a 200lb rider???
    Also, what has everyone else been doing with thier 450x suspension? Might be nice for you all to chime in with your height/weight and mods. :idea:
    $1500 worth of mods to realize I cant buy skill!
    by crfsonly » Tue Feb 13, 2007 10:28 pm
    210 is too heavy for the stock suspension. then you add another 20lbs. for gear and you're way over the designed spring and valving on the stock suspension.
    springs are a must and if you can revalve it all the better.
    Eric Mac
    by Eric Mac » Tue Feb 13, 2007 10:38 pm
    Ken,
    I already ordered the rear spring. Can you tell me what the rate on the front springs is and what I should buy?
    by crfsonly » Tue Feb 13, 2007 11:03 pm
    race tech's website has a spring rate calculator that will tell you the spring rates. from their calculator you'll need a 0.48kg/mm fork spring rate.
    factory connection offers great springs...you can find them in our online catalog.
    thanks,
