If you plan on Jumping, Racing, and doing everthying awesome...ditch the 150F and (if the 150 "size" is what you really want) go to the 150R (probably should think even about the 250R at 155lbs...keep in mind, the 450 is factory suspended for a 160 lb. rider.) This is based on my assumption you're looking to do MX and your looking to do it in the 85 class (150) or the Lites class (250.)satisfied wrote:So, if I plan on jumping, Racing, and doing everything awesome (I weigh 155lbs) what springs should I get for my CRF150f?
Yup...hammer and punch. I use the same method. I don't use an actual "punch" as the tips of those things can be pretty sharp and leave dings in the lock nut. I use a small steel bar, but with a flatter end that fits more exact in the slots of the lock nut.djh65 wrote:I went to get the spanner to loosen my rear suspension. Then I looked and wondered how to get it in there. The guy at the shop suggested hitting it with a punch and hammer to loose in then use the same to tighten it. Any thoughts.
