WD-40
    hondafan
    WD-40
    by hondafan » Sun Sep 19, 2004 6:34 pm
    Hey this is one for the 2 stroke riders. if your pipe leaks like mine you can spray WD-40 on the area that is affected, let it sit for maybe 2 minutes, and hit it with pressure wash.. comes right off.
    And for both 2 and 4 strokers: chain oil.... flys off... WD-40....pressure wash... get it??
    Just a tiny bit from the vast knowledge of hondafan.
    2008 crf 450
    sold-2001 cr250, 2004 crf150, 2003 cr250, 1991 KX80, 2003 TT-R125
  • crf150racer2
    WD-40 Reply
    by crf150racer2 » Tue Sep 21, 2004 6:39 pm
    That never works on my nephews RM60
    But anything works on my CRF 150F
    GO CRF150 AND ALL CRF'S
    wade
    size
    by wade » Wed Sep 22, 2004 6:36 am
    To the left of the keyboard is a button that says "Caps Lock" try it out. :twisted:
    Tree....what tree?
  • crfsmylife
    by crfsmylife » Fri Oct 15, 2004 7:58 am
    my friend got a 02 cr80 and the pipe has been leaking so much we dont know were its coming from the bike dont even start now lol
    MY BIKES
    crf50-04
    crf50-04
    crf100-04
    hondafan
    by hondafan » Fri Oct 15, 2004 2:26 pm
    yes CRs are bad about leaking. i ran into a guy that had an '01 250 and his leaked in the same spot as mine. i would say this is normal for all CRs. although it gets on my nerves!
    2008 crf 450
  • chondamx
    by chondamx » Mon Feb 28, 2005 7:30 pm
    Also another tip for WD-40, anybody that's ever greases baerings knows that grease is a pin to get off after it's smeared all over your hands. So shoot WD-40 all over your hands and the grease (it's a degreaser) will come right off when wiped with a shop towel.
    Chris
  • redrider911
    works pipes on two strokers
    by redrider911 » Tue Mar 01, 2005 7:27 pm
    heres one. Use mag wheel cleaner on your "works" pipes. it brings it back to like new! Then coat it with wd-40 before it flash rusts
  • EWP Zoul
    by EWP Zoul » Sat Mar 19, 2005 3:47 pm
    I always use WD-40 when i am washing my plastic. leave a nice shine on it when I am done....and no water spots \:D/
    EWP Zoul
    2004 CRF 450R #19
    Works skid plate
    1990 YZ250
    If it ain't broke.....
    You are not riding it hard enough!!
  • redrider911
    by redrider911 » Sat Mar 19, 2005 5:48 pm
    yeah and it is easier to wash after the next ride. The mud doesnt stick as much!
  • crispy
    by crispy » Sun May 08, 2005 9:41 pm
    I saw the comment on CR's leaking...my girlfriend just got a '02 CR80 and it leeks like a sieve out of the header tube pipe. Is there anything that can be done and is this going to be a problem other than pissing off all the hairbags??
    LIFE'S TOO SHORT NOT TO 450!
    by crfsonly » Sun May 08, 2005 9:46 pm
    turns out i have personal experience with the cr80...it was my son's first bike. if you get the mix ratio correct it will help to some degree...however, the best thing to do is stay on the pipe...this is when the bike i burning as clean as possible. you'll never get rid of it all but mix and rpms makes a big difference.
    by Old Dude » Thu Aug 25, 2005 12:20 am
    Its great for taking off that sticky crud that is left when you take stickers off too. Clean your chain real well with it after you wash it. The WD stands for water displacing so you chain doesn't rust. Wipe or brush the chain then lube it real well. Buy it by the gallon and put in a spray bottle (cheaper in the long run)
    Great Stuff that WD40![/b]
  • DaveX
    by DaveX » Wed Nov 02, 2005 6:23 am
    I have read a ot of people recommending wd-40 for the chain after washing your bike, which is what I do. I have been told that wd-40 will damage the seals in a O ring or T ring chain. Does any one know ?
    Thanks - Dave
    oldtimer
    by oldtimer » Wed Nov 02, 2005 7:16 am
    Can’t say for sure... In principal yes. It should eventually dry them and the lube behind the ring out.
    Before switching to non sealed chains I also used WD-40 on just about everything on my bike except rotors, tires, plastic and electronics. I did this for almost 2 years with no “noticeableâ€￾ breakdown of the rings.
    I still use the WD on everything else.
    I basically got lazy and decided to soak my chains in cleaner then oil until the next ride. So I switched to unsealed.
    06 CRF80
    04 CRF70
    88 CR250
  • gprodick
    by gprodick » Fri Nov 04, 2005 8:33 pm
    I use WD40 exclusively on my chains. I always wash my bike after riding and always WD40 the chain. I've not had any problems. I probably have 1500 miles on my X and have only had to adjust the chain once. Even then it was only a slight adjustment.
    I've used it on my CR500 and almost never need to adjust the chain. It seems to work just fine.
    If I put chain lube on it, I just end up with a mess after I ride. I don't know what to tell you. WD40 seems to work.
    CRF450X,RaceTech,Rekluse,Scotts Stab. & disc guard, Flatland rad guards,IMS 3.2, E-Line skid, No-Toil w/stock screen
    Stock pipe,Ride @ 5000'-10,000'
    Air box top & sides, JD 45 pj 160 main red needle-#4
    FS 1 1/2
    Other bike CR500
