by JimDirt » Fri Jul 19, 2019 12:17 pm
No problem ... Like I mentioned , I think the 09-16 one is about your only choice at this point ....
If you can , take some calipers , and find someone with a 09-16 and ask if you can measure their opening (the inside diameter) , and confirm it is the same as yours , if it is , then it will probably work , if it is really close , it still might work because there is a lip on the sock that should hold it in place depending on the difference in opening size ..... keep us posted .............................
