450x fuel screw
  • DiagTech
    450x fuel screw
    by DiagTech » Sat Jan 21, 2017 1:57 pm
    So I finally bit the bullet and bought a couple new bikes for me and my son. I had an '07 450x. The '16 is a bit more of a pain in the rear to do stuff to. Removing the fuel screw being the biggest one.
    I finished my sons 250 with little problem once I found out about a really screwed up pin blocking access to the screw. Got everything done on mine up to the removal of that screw. I have tried 2 different fuel screws on mine. Neither will install more than a half turn. It then feels like cross threading or incorrect thread pitch. The original screw threads in fine.
    If it matters, one was an R&D and the other was a Moose Racing/Zip Ty piece.
    Any ideas?
    Kevin
  • DiagTech
    by DiagTech » Sat Jan 21, 2017 3:02 pm
    In the words of Rosanne Rosanna Dana......
    Nevermind
    Kevin
    by JimDirt » Sun Jan 22, 2017 9:29 am
    LOL ..... what was the issue ?? , was the old O-Ring and washer still in there holding the screw out ??
  • DiagTech
    by DiagTech » Sun Jan 22, 2017 3:51 pm
    Nothing in there. Just wouldn't turn. I think the threads on the R&D screw were a bit buggered to begin with, but not sure because the other new one wouldn't install either. I just kept turning it in and out slightly and it went.
    Kevin
    by JimDirt » Mon Jan 23, 2017 9:52 am
    Hmmm... that is strange , both my bikes have R&D screws and they went right in ... :?
    by Back2-2 » Mon Jan 23, 2017 10:18 am
    For what it's worth -
    If that is case the you should take it back out and blow through it - inside to out to be sure the small debris are cleared.
    That was a gutsy move - if that would have went south on you it would have been a real challenge to correct. Thread chasers are priceless for those kind of situations.
    by JimDirt » Mon Jan 23, 2017 4:33 pm
    In addition to what Neil mentioned , you might want to contact R&D and explain the situation , they may just send you a new one if its defective , since with messed up threads , it might not adjust correctly , thats the point of having it , is ease of adjustments... plus as he mentioned , if debris gets to the O-Ring , it will damage it and then you will have a lean condition
  • DiagTech
    by DiagTech » Fri Feb 03, 2017 7:38 pm
    Once I installed it all the way, I did pull it out to inspect it and the carb. It reinstalled fine the second time.
    I thought about a thread chase, but I just didn't feel like driving 10 miles to get one.
    Kevin
