JimDirt wrote:Got ya , yea that is the end seal in the stator cover , i completely forgot about it , it keeps the oil pressure from the oil filter to the crank , if the brass piece gets damaged the engine will not get lubricated properly , so its a good thing you pulled it apart , i was thinking you were talking about the crank seal , my bad
Looks like you have the same issue as the other guy , the seal most likely got brittle from the engine heat , it does happen , but its not very common
Just remove the snap ring and remove/replace the seal , its real easy
As for the knock , hopefully its not from lack of oil to the rod , if it is a rod knock , its crank time , if its as the other poster at TT then its the piston , if the knock does not stop after the seal replacement and you pull the head/cylinder/piston , you will be able to move/rattle the rod around by hand and tell if its solid or not , if it has any side and/or up/down movement , or any binding when turning the crank by hand while holding the rod , then the crank is done
