TRX450 Piston Kicks over.Electric Start will not.
    smitty250x
    by smitty250x » Tue Oct 06, 2015 12:52 pm
    Hey fellas,
    Had my local Honda mechanic rebuild my 2006 450X with a TRX piston and KW SS valves.
    He called and told me the electric starter won't turn it over and it can be kicked but is very hard.
    Can I use an Electric starter motor from the TRX450?
    and could it be anythings else.
    Thanks.
    2005 CRF 250X
    2006 CRF 450X
    by JimDirt » Tue Oct 06, 2015 1:19 pm
    He does not have the De-Compressor gap adjusted correctly ..... are you sure this guy is a Honda mechanic ?? , he should know this ...
    smitty250x
    by smitty250x » Tue Oct 06, 2015 1:37 pm
    JimDirt wrote:He does not have the De-Compressor gap adjusted correctly ..... are you sure this guy is a Honda mechanic ?? , he should know this ...
    The de-compressor is something we have talked about. It was all set by the factory specs. We are re-checking it.
    2005 CRF 250X
    2006 CRF 450X
    by JimDirt » Tue Oct 06, 2015 1:43 pm
    if its off , even just a little , it will make it hard to start
    smitty250x
    by smitty250x » Tue Oct 06, 2015 1:46 pm
    would the trx piston need or justify a different gap?
    2005 CRF 250X
    2006 CRF 450X
    by JimDirt » Tue Oct 06, 2015 2:32 pm
    No , the gap has to do with the valves and timing not the piston , in the sense that the type of piston is not so much as a factor as the compression of the piston is , the gap needs to be 0.014 period , if its 0.012 or 0.016 it will be enough to make a difference in how it starts , a higher compression piston will make it even more critical to get the gap correct , lower compression is more forgiving
    smitty250x
    by smitty250x » Tue Oct 06, 2015 2:35 pm
    Thanks for the info. Hope this is the issue.
    Will update later.
    2005 CRF 250X
    2006 CRF 450X
    by JimDirt » Tue Oct 06, 2015 2:37 pm
    sorry was editing as you were posting ...
  • driver3
    by driver3 » Sun Nov 08, 2015 3:15 pm
    If the decomp was set incorrectly, he may have already burned up the starter. If you get it set right, and it still doesn't work, I'd take the starter solenoid out and have it checked at a motor shop. You can get a rebuild kit and rebuild the starter for less than half the price of a new one.
    CRF250XRider
    by CRF250XRider » Thu Nov 12, 2015 1:33 pm
    I had this problem with my CRF450X. Found that the centrifugal weight spring was not on the weight and the keeper plate was not installed correctly. The weight was free floating in the assembly.
    You're not at fast as you used to be, but you're not as slow as you're going to be.
    05 CRF250X (my bike)
    05 CRF450X/R (my new bike)
    13 CRF250R (son's bike)
    Harkon
    by Harkon » Mon Nov 16, 2015 2:14 pm
    Also, if it;s that hard to turn over, stop kicking it. You don't want to bust anything. ;)
