JimDirt wrote:Just so you know , that 450R motor in the For Sale section will not bolt up in your X , the frame is a different width and nothing will fit
Unless you have "other" plans , but it wont work in the X frame
chopper wrote:JimDirt wrote:Just so you know , that 450R motor in the For Sale section will not bolt up in your X , the frame is a different width and nothing will fit
This is not accurate, if you so choose you can in fact mount any 05-08 450R motor into the 450X frame. This is a direct bolt in swap, of course the 2 best features of the 450X will be lost in the swap (e start & wide ratio gearbox).
crazybrother wrote:chopper wrote:JimDirt wrote:Just so you know , that 450R motor in the For Sale section will not bolt up in your X , the frame is a different width and nothing will fit
This is true but you will need the 450R motor mounts
