Alright, I've removed the bearing retainer from the rear wheel after much difficulty and a $30 Motion Pro tool. I've got new Pivotworks bearings to go in. I can't get the damn bearings out.
I've watched a few videos on the 450R rear bearing removal, same as the 450X. Everyone seems to have a loose collar between the bearings and it just pushes aside to allow the single bearing on the brake side to be punched out. I've bought a few punches and drifts and can't seem to get mine to move out of the goddamn way to allow access to the single bearing. Pullers won't work given that there's a lip on the inside of both sides that won't allow the bearing to be pulled out by a conventional puller, and that would assume that the collar isn't in there anyway. Am I doing something wrong, or is there something I'm missing here...?
