by Back2-2 » Sat May 02, 2015 12:06 pm
I believe that is your crank case vent tube that goes on the top of your valve cover. That tube is the vent for the top end valve area and the "T" is where the transmission vent meets the valve cover vent. Then after the "T" the tube goes down behind the engine. There is a plug in the end of the tube to occasionally drain condensation / oil residue. Seems that I recall a tube being tied to that also to send the crank case fumes back into the air box ?
So look on the top of the valve cover and the air box and I think you will find the open port / nipple.
