2009 CFR450X Seattle WA
I am pulling my hair out trying to figure out why this bike does not like full throttle!!!
I have so far:
Air box mod (top and sides).
New plug
New air filter
JD Jetting kit as per their specs (165 main, red needle 4th clip from top, 50 leak, air screw 1 3/4 out).
Tokyo Mods smog block off kit.
Have checked:
New 92 gas
Fuel filter supply/breather not blocked
Carb stripped and cleaned
Left to check:
Swap around main jet sizes and needle position
Valve specs
Valve timing not jumped
Check grounds on electrics
Change plug out.
It pulls very strong from low down to mid 3/4 throttle - but then holds back, not really misfiring, more of a drastic reduction in power and just not running good. I started off with a 165 main jet (As per JD Jetting recommendation) went up to 170, down to 160 and couldn't notice any difference???
I would appreciate any help tying to figure this out as i am on a bit of a learning curve with these four strokes.
