Carb question
  • gobigohome
    Carb question
    by gobigohome » Thu Oct 09, 2014 2:00 pm
    So I had my bike in storage for a couple years, so needless to say I was a little rusty on the tear down and rebuild of the carb. I had to clean all the jets and change some jetting due to elevation. I got it all back together but when I turned the gas on it started pour out the outlet tube on the bottom of the carb. I made sure the gas drain screw on the bottom of the carb was closed but is still coming out.
    Any thoughts on what could be going on? Could the float be stuck open? I did not think it would still come out the drain on the bowl.
    Any help or thoughts would be greatly appreciated
  • hall_philip
    by hall_philip » Thu Oct 09, 2014 9:24 pm
    yes your float is stuck, if you have a gauge I believe it needs set at 8mm? check the manual don't take my word for It.
    by JimDirt » Thu Oct 09, 2014 10:42 pm
    Yes ! , its 8mm
  • gobigohome
    Thanks
    by gobigohome » Fri Oct 10, 2014 12:26 pm
    When you mean 8mm is it a setting or jet. For my ignorance can you put it in lamen terms for me exactly what is meant or the procedure to do it. I have also tried to search for this but was hard to find the straight answer.
    by JimDirt » Fri Oct 10, 2014 4:42 pm
    Float is 8mm from carb surface while holding carb sideways
  • gobigohome
    by gobigohome » Fri Oct 10, 2014 7:57 pm
    Thank you that was very helpful. I will have to find the float gauge tool
    by JimDirt » Sat Oct 11, 2014 2:52 pm
    Krannie
    by Krannie » Mon Nov 17, 2014 7:45 pm
    A stuck float has nothing to do with the float itself.
    The float needle gets caught up in it's cavity due to corrosion, and will get stuck.
    You need to pull the float needle, polish it, and polish the cavity it sits in, so it will slide without issue.
    You should also inspect the tip of the needle (rubber) for any marks....replace it if you see any rings in the rubber.
