Front head light on my 2006 CRF450X HI/Low
  • dlee
    by dlee » Thu Jun 12, 2014 1:38 pm
    Ken, or anyone else,
    My 450X is street legal, well kinda. I would like to finalize it just in case I get pulled over. I don't have a high/low beam on this bike, but was wondering if I can use the same head light. Anyone have a way to utilize the stock head light? I ordered a bar mount switch system, so I can toggle my hi/low. It also has a horn push button on it
    Any input would be great
    Thanks
    I didn't vote for him
    2005 CRF450X
    crazybrother
    Re: Front head light on my 2006 CRF450X HI/Low
    by crazybrother » Thu Jun 12, 2014 2:34 pm
    dlee wrote:Ken, or anyone else,
    Thanks
    Yes, the stock headlight has a Hi/Lo beam built in. It's just not wired up. Look at the connector and you will see three wires to the light and only two from the bike's wire harness.
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
  • dlee
    by dlee » Fri Jun 13, 2014 4:33 am
    Thanks crazybrother!
    2005 CRF450X
  • dlee
    by dlee » Fri Jun 13, 2014 4:35 am
    would you happen to have a wiring diagram? I am installing a bar mount switch for a horn, and high/ low switch
    Thanks
    2005 CRF450X
  • MX_RACER1
    by MX_RACER1 » Fri Jun 13, 2014 6:45 am
    Not sure what state you are located in, however in Pennsylvania the stock light no matter if the High / lo function works or not would not pass inspection.
    In Pennsylvania the headlight must come on without the engine running.
    This is why the Baja Designs (and other kits) are popular.
    I priced out doing the conversion myself and it is a little cheaper but to have a company take the time to neatly put it all together so that it is plug and play... PRICELESS!
    crazybrother
    by crazybrother » Fri Jun 13, 2014 9:00 am
    There's one in the OEM shop manual.
    2010 Honda VFR 1200
  • dlee
    by dlee » Sun Jun 15, 2014 4:30 am
    Thanks again Brother!
    2005 CRF450X
