What do I need to adjust?
Posted: Mon Jun 09, 2014 4:05 pm
by goodquest
I just went from a stock air filter to a No Toil Dual stage filter and my bike runs, but
Seems to stall upon quick throttle blips and just does not runs as well. What adjustments
Do I need to do.
Other suggestions welcome.
Thanks
Posted: Mon Jun 09, 2014 6:11 pm
Start with Fuel Screw , turn it in till just seated and count the turns , you should be between 1 1/4 -2 3/4 turns out , if it wont run better within that range then you need to re-jet , larger main , maybe lower the clip on the needle to 4th position , that should get you started in the right direction
Posted: Tue Jun 10, 2014 5:33 am
by MX_RACER1
Jim is on the money.
Fuel screw should get you there.
Posted: Tue Jun 10, 2014 11:33 am
by goodquest
If I remember correctly I have a 168 main and a 48 pilot. I will adjust fuel screw and see what happends.
Thanks for you help.
Posted: Tue Jun 10, 2014 11:54 am
What is your elevation (or the elevation you normally ride)
This is the guide for jetting
Jetting Guide for Main Jet:(pilot 45)CRF450R/X
Sea level...165
2000 ft.......162
4000 ft.......160
6000 ft.......158
8000 ft.......155
Temperature/Elevation:
One main jet size (up/down) for every 2,000 feet or 25 degrees in temp.
Posted: Tue Jun 10, 2014 1:41 pm
by goodquest
JimDirt wrote:What is your elevation (or the elevation you normally ride)
Sea level...165
2000 ft.......162
4000 ft.......160
6000 ft.......158
8000 ft.......155
Thanks for the information. I'm in California
so the areas I ride in range from 30 Sacramento
to Forresthill 3225.
Once it cools down, I'm going to try the fuel screw adjustment.
Thanks again
Posted: Wed Jun 11, 2014 6:16 pm
by goodquest
Ok, Where is the fuel screw? Anyone have a picture or location?
Thanks
Posted: Wed Jun 11, 2014 6:32 pm
Bottom of the carb at the front of the bowl
You need one of these , it will make life easier so you dont have to loosen the carb and twist it sideways to adjust the fuel mixture
http://www.crfsonly.com/catalog/product ... ts_id/2792
Posted: Wed Jun 11, 2014 7:32 pm
by goodquest
Posted: Thu Jun 12, 2014 5:51 am
by MX_RACER1
External fuel screw adjuster is a must. If you have big hands make sure you get one that has a flex neck and can be mounted further to the outside of the carb like the link that Jim Dirt gave. There are others that are just a big finger screw. They work well too, just not as simple to get at.
Posted: Sun Jun 15, 2014 11:59 am
by goodquest
I purchase the oversized fuel screw and adjusted the fuel screw (Mr smiths directions) and still have everything from quick throttle flame outs, or bogs. It’s odd I can do 6 quick throttle twists and on the 7th it will flame out or die. It back fires sometimes and it just doesn’t run well. I went back to a stock air filter and still have the same problem. The Honda service Advisor told me to go to a 50 or 55 leak jet and go down in the pilot. I guess it’s just a coincidence that all this happened after changing the air filter, but It sure got me baffled.
Posted: Sun Jun 15, 2014 3:07 pm
I have a question , are you oiling the crap out of that No-Toil filter ?? , if you are your starving it for air and that would make it bog,pop,stall
With a #45 pilot and a main in the area of 160 - 165 and the fuel screw between 1 1/4 - 2 3/4 , the bike should run fine
Rule out that the squirt is not hitting the slide when blipping the throttle (engine off , airbox off/ subframe up) and look to see down the throat of the carb if it just barely misses the slide , if the stream hits you need to adjust the AP timing , also try taking a small O-Ring and putting it around the AP screw and the stop
I thought there was a post here , but this is the only one i could find that has pictures to show you what to do , but this might help stop the bog
Also , if your rev-ving it on the stand it will bog /pop/stall sometimes , so make sure it runs fine under load , on the stand means nothing (sorry Ken for the link to that "other" site)
http://www.thumpertalk.com/topic/539540 ... or-an-fcr/
Posted: Sun Jun 15, 2014 8:57 pm
by goodquest
JimDirt wrote:I have a question , are you oiling the crap out of that No-Toil filter ?? , if you are your starving it for air and that would make it bog,pop,stall
No I did not over oil the filter. I even went
back to a stock pre-oiled filter to make sure.
I tested the bike under load with same results.
I will have to look up ap timing.
Thanks for the suggestions.
Posted: Mon Jun 16, 2014 3:35 am
by crazybrother
What year is your 450? And what have you done as far as MOD's?
Your pilot is a little too large. Try a 45 or even a 42.
Adjust the fuel screw this way and the bike will tell you what it wants for a pilot,
Setting the fuel screw mixture-
Try adjusting with the motor fully hot, and turning the fuel screw inwards until the idle slows or runs rough, then turn outwards 1 1/4 turns from this position. For example, if the idle slows or runs rough at 1/2 turn, then set the fuel screw to 1 3/4 turns out (1/2 + 1 1/4 = 1 3/4).
See-
http://www.pbase.com/jdjetting1/image/82894252 to understand how the fuel screw can affect the idle speed and air/fuel mixture at idle. The target range for the air/fuel mixture is near 12.5 to 13:1 at idle.
Posted: Mon Jun 16, 2014 5:13 am
by MX_RACER1
Everything I've read to this point I agree with. You mentioned one thing that raised my ears a little. You said that you can rev is 6 times without issue then the 7th it would flame out.
While you have the bowl open. Make sure that your floats are not stuck creating a false lean condition.
