by JimDirt » Thu May 15, 2014 7:16 am
I am just guessing here (for obvious reasons) , but if it has a Mode and Set button , Mode should change it from MPH to KPH (in ODO Mode)
If its just the "joystick" then i would guess try pushing it in using the left and right buttons at the same time or if its a true Joystick with only 1 single item to move then push it IN ,holding until the readout starts flashing then use one of the buttons (top,bottom,left,right) to change the KPH and MPH
Also very important , the MPH to KPH should only be able to be changed when in the ODO mode not Trip mode
