CRF 450 X exciter coil peak voltage
  • fireball
    by fireball » Mon Mar 03, 2014 4:36 pm
    Hi
    I want to check my exciter coil peak voltage, but it isnt in the service manual. Who knows, what is the minimum peak voltage on the exciter coil ? I measured coil resistance, it was ok, but stator can be bad, if the ohm is ok. I have very weak spark, I tried with an other cdi , same result.
    the R service manual writes minimum 50 volts, but it has a different type stator.
    thanks
    here is my bike ;)
    by Aussiecrf230 » Mon Mar 03, 2014 10:42 pm
    You will need to make yourself a peak voltage adapter if you wish to measure it with a multimeter.
    A few dollares in parts, build a ful wave rectifying version, just goggle circuit diagrams for.
    Pulse generator peak voltage 0.7v min (disconnected and while the engine is being cranked)
    Exciters normally minimum 100 volts.
  • fireball
    by fireball » Tue Mar 04, 2014 2:17 am
    Hi
    I measured the ignition pulse generator peak voltate ,too it was about 1 volt,that's ok, the exciter coil peak voltage was about 20 volts . I tought that is low. I did the measurements with an oscilloscope.
    when I push the start button, I have weak spark, or no spark. I tried it an other CDI too, but the spark was very weak, the bike doesnt run.
    Now one of my friend rewinding the exciter coil, I hope that it will solve the problem :)
Users browsing this forum: Google [Bot] and 6 guests
