by JimDirt » Tue Dec 10, 2013 4:07 pm
Use this guide as a baseline
Sea level....165
2000 ft......162
4000 ft......160
6000 ft......158
8000 ft......155
I ride between 2000 to 8000 and run a #162/45 , Needle on 4 clip position from top , #65 leak jet , 1 1/2 turns out on fuel screw , i have airbox cut,R muffler,HotCams Stage 1...06 X
So if you are around my elevation , then what i have should be close enough for your bike , if different elevation , keep everything as mine is (basically) and adjust the main jet size according to your elevation.....or just do what everyone else around here does (excluding me) and get a JD Jet Kit
