Locked 28 posts
Help with carb fuel screw !!!
  • axarob44
    by axarob44 » Fri Oct 04, 2013 4:00 pm
    Im sitting here half sick to my stomach. I have a brand new 2013 450x. I got all the same parts I had on my 06' 450X and I get to the damn fuel screw to replace it with the R&D flex screw. My damn carb has a friggin' plug in that I dont know to get it out. If I had known that it was plugged I probably would have just left it stock. Can any one give me some help with this. I dont know what to do. I have every thing all ready to go, exhaust , JD jet kit, Twinair sealing ring, air box cut. I'm pissed! If you can help,please do. Thank you. Andy
    by JimDirt » Fri Oct 04, 2013 5:10 pm
    I have not messed with a 13 yet
    but
    You should be able to pop out or drill out the plug or maybe unscrew the plug , the fuel screw will be under it and remove normally
  • axarob44
    by axarob44 » Fri Oct 04, 2013 5:16 pm
    I really cant see any other way to get it out. Drilling makes me nervous. I plan on drilling unless someone has a different method? Thank you for the reply JD.
    gal8x
    by gal8x » Fri Oct 04, 2013 6:02 pm
    Honda has been using plugs to cover the air/fuel screws for decades. It has to do with California emissions? It is a standard procedure (you can find it in many service manuals)to drill a small hole so the cap can be pulled out.
    It does not need to be replaced.
    Wrap lots of gray tape about 1/8” from the tip to act as a stop. Use a new/sharp bit and be slow and deliberate. You will be fine.
    Use the force young padawan.
    2005 CRF450X (plated)
  • axarob44
    by axarob44 » Fri Oct 04, 2013 6:10 pm
    Thanks gal8x! I'm going to do the drill. I guess I just needed some encouragment and know thats how its done
    by JimDirt » Fri Oct 04, 2013 6:48 pm
    gal8x wrote:Honda has been using plugs to cover the air/fuel screws for decades. It has to do with California emissions? It is a standard procedure (you can find it in many service manuals)to drill a small hole so the cap can be pulled out.
    Thats what i like about the 06 , no smog pipes or crap , and no plug on the fuel screw and it came with a 2.3 tank instead of a 1.9 (stupid for off road) , but , for some reason they feel everyone has to comply to California emissions and they dont want you to adjust anything
  • axarob44
    by axarob44 » Fri Oct 04, 2013 6:54 pm
    I used to have 2006 model and everything was easy peasy with hop ups.
    I figured it would be the same with this new one. Just felt horrible having to drill on it and possibly screwing it up
    by JimDirt » Fri Oct 04, 2013 7:36 pm
    Yea , i had a new 87 Toyota truck and it had the 22R with a carb , i lived in California at the time , i had to drill out the plug on it to adjust the air screw , its just the EPA that is doing this , the manufacturers don't want to do it , but they have to in order to sell them in Cal , and now they want every state to conform to Ca standards , its stupid , and all it does is make more work for the enthusiasts that want their cars or dirt bikes to actually run worth a crap
    And that is why i still have my 06 , i got it new and honestly , there is nothing on the new ones that interest me , i would have to add more hop ups then i already have on mine , just to get it to run close to what mine already runs like , so i am already ahead of the game by keeping what i have had , about the only thing they would do that would interest me in a new one would be FI , but if its going to add another 20 lbs , then i would rather do without it
  • axarob44
    by axarob44 » Fri Oct 04, 2013 9:25 pm
    I went a few years without a bike. I really regretted getting rid of my x. It was a great bike all the good mods done, exhaust, cam, jetted. It ran really nice. I figured I would get another and now I have to deal with all this Califonia bs. I just want to get back to were my 06 was. I just hope I can get this carb straightened out with out messing it up. I hate even having a new bike all torn apart. I kind of wish I would have bought the 450r.I ride tight trails anyways
    by JimDirt » Fri Oct 04, 2013 10:13 pm
    All you need to do is jet it for your elevation , cut the top of the airbox (you dont have to do this , but it helps) , put a 52 rear sprocket , and maybe a HotCams Stage 1 , and it will be a reliable non stalling (unless you really screw up) fun trail bike (though i also recommend re-valving the suspension and springing it for your weight)
    So minimum
    52 rear sprocket
    Re-jet for elevation
    1.6 bar radiator cap
    Engine Ice coolant
    crazybrother
    by crazybrother » Sat Oct 05, 2013 11:41 am
    Woah, no need to drill anything. It's a D shaped fuel screw, either get a D shaped tool or an electrical connector/butt can be shaped or even easier is to just remove the float bowl and then it will unscrew in your hand using a pair of pliers!!!!!!
    This is what you need:
    http://www.crfsonly.com/catalog/product ... ts_id/3294
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
    by JimDirt » Sat Oct 05, 2013 12:08 pm
    So your saying your new X did not come with a plug covering the hole for the fuel screw from the factory ??
    crazybrother
    by crazybrother » Sat Oct 05, 2013 12:31 pm
    JimDirt wrote:So your saying your new X did not come with a plug covering the hole for the fuel screw from the factory ??
    No plug, just the D shaped fuel screw...
    2010 Honda VFR 1200
    by JimDirt » Sat Oct 05, 2013 12:36 pm
    I am wondering why the OP has a plug in his then ??
    I know mine did not have anything resembling a plug , and the fuel screw was a slot on mine not D shaped (i got mine brand new in 06) but mine is a non Calif , non smog model, it had no smog pipe on the cylinder , so maybe they do them differently depending on the restrictions on them in the particular state they are first sold , since he seems to be back east , maybe the restrictions/specs there are not the same as Calif , or Idaho (though i have not personally looked to see if there is a plug on the 12/13's at the dealers here yet)
    crazybrother
    by crazybrother » Sat Oct 05, 2013 1:35 pm
    I had an '06 too, which had the slotted fuel screw. The newer models changed to a "Tamper Proof" design, I don't think he has a plug, he's just confused the D shaped with a plug because it's not adjustable... But it is with the right tool!
    2010 Honda VFR 1200
Locked 28 posts
