Problems with IMS 3.2 tank on my new 2012 450x.
    crazybrother
    by crazybrother » Thu Jul 18, 2013 5:19 pm
    Hey, if anyone is having problems fitting your IMS 3.2 tank on your 2009-2012 450x. I have found a solution, I contacted IMS directly and they are aware of the issue and will send you two lowering brackets that will work great. Just wanted to pass this on, so you don't have to tweak your shrouds.
    Here are a couple of pic's.
    The Mohard Rad guards didn't matter, they didn't fit either way.
    Hope this helps anyone.
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
    by crfsonly » Thu Jul 18, 2013 8:00 pm
    so the only issue was the lower shroud mount? the shroud fit well on the tank itself? also, your comment about the mohard rad guards, you are saying they did nit fit with the IMS tank? both are news to us if this is the case.
    crazybrother
    by crazybrother » Thu Jul 18, 2013 10:20 pm
    crfsonly wrote:so the only issue was the lower shroud mount? (Yes) the shroud fit well on the tank itself? (Yes) also, your comment about the mohard rad guards, you are saying they did nit fit with the IMS tank? both are news to us if this is the case.
    They did fit but not very easily, I had to force them. Although they fit perfect with the stock tank and shrouds. And IMS is aware of this, it seems to be a batch problem. So if you hear of anyone else with this issue, you can call IMS and they should take care of it or maybe you can get a few sets of the brackets just in case...
    2010 Honda VFR 1200
    crazybrother
    by crazybrother » Thu Jul 18, 2013 10:23 pm
    Sorry Ken, your last question... I misunderstood you. The Mohards always fit perfect, with the stock tank and the IMS... No issues at all.
    The shrouds are the only issue.
    2010 Honda VFR 1200
    by crfsonly » Fri Jul 19, 2013 8:26 am
    thanks for the clarification. your statement "The Mohard Rad guards didn't matter, they didn't fit either way." was where I was confused on the guards.
