BOG DOWN
  • ocliff4
    BOG DOWN
    by ocliff4 » Tue Jan 30, 2007 9:56 am
    I have a 06 450x,I just opened the air box and removed
    the baffel from the muffler,went out riding the bike runs
    great except for when I open the throttle too quick it
    bogs out or stalls.it runs fantastic in the high rpm range.
    do I need to change jets if so which one would be the best??
  • nedirtbikr
    Re: BOG DOWN
    by nedirtbikr » Tue Jan 30, 2007 10:34 am
    ocliff4 wrote:I have a 06 450x,I just opened the air box and removed
    Take a look at the JD Kit. A lot of the X owners use them and love 'em. I use it myself and am very happy. There are some other mods you can do too (pink wire, fuel screw, updgraded air filter, quickshot, etc.) Do a search...there is a ton of info on those things here. I'll look for some links.
    2006 CRF450R (For Sale)
    dlpmx
    by dlpmx » Tue Jan 30, 2007 10:36 am
    If you opened the air box and didn't rejet your too lean.
    Dale
    All mods listed in the Garage
    Crf250girl
    by Crf250girl » Tue Jan 30, 2007 10:39 am
    http://www.geocities.com/catpoopman/sv650_rejet.html
    I don't have a X or a 450 but my bike did the same thing and my dads buddy thats a Ford mechanic told us how to do this, read on this website, hopefully it'll help.
    #124 Sarah W. ~2004 Crf250r~
    RiDe ReD
    Devol Suspension
    Fmf titanium pipe
    Dragon
    Fox(trail)
    Thor(Racing)
    Oxtar Pros
    dlpmx
    by dlpmx » Tue Jan 30, 2007 3:17 pm
    Good web site but way harder. Loosen the carb clamps, rotate the carb. Remove the float bowl drain. The main sits right there. Most guys here will tell you to buy a JD kit. I will also . Makes things a lot simpler.
    Dale
    by [email protected] » Wed Jan 31, 2007 2:57 am
    Oh yes, then it will run fantastic everywhere, you're going to be a very happy owner when you get 'er done !
    Here you go,this is what dplmx is talking about,and in that one box is the answer to your problems. Just follow the directions, it's very straightforward and easy. You'll love how your bike runs :
    http://www.crfsonly.com/catalog/product ... ts_id/1093?
    This will help you learn your way around the carb,print it,read it,keep it :
    http://crfsonly.com/howto/450x/jetting/ ... needle.php
    Doug
  • ocliff4
    BOG DOWN
    by ocliff4 » Wed Jan 31, 2007 9:42 pm
    thanks for all the tips,ill give it a try!!!!
    by JAWS » Wed Jan 31, 2007 10:14 pm
    While you are doing your jetting, and if you get the JD kit, do the o-ring AP mod at the same time. It is the best bang for the buck for the throttle-snap bog, after getting the jetting right.
  • ocliff4
    o-ring mod??????
    by ocliff4 » Thu Feb 01, 2007 8:58 am
    can you explain the o-ring mod???thx..
    by JAWS » Thu Feb 01, 2007 9:14 am
    If you get the JD kit, it comes with it. Basically you install a small rubber o-ring over the accelerator pump actuating arm that will change the timing of that event. There is a delay gap built in and the o-ring will affect that gap timing.
    Here's a little light reading:
    http://crfsonly.com/forum/viewtopic.php ... ight=oring
