Scotts Stabilizer
    coljam
    Scotts Stabilizer
    by coljam » Thu Jan 25, 2007 7:48 pm
    Disclaimer: I have searched the forums and have not seen my question answered explicitly.
    I've got an 05 450x with stock bars. I also have a trail tech computer, which mounts forward of the bars.
    I am planning on adding a Scotts stabilizer. However, when I look at the various mounting options, I find myself a tad confused.
    Could someone simplify the "choosing" process a little?
    Thanks.
    Z
    by Z » Thu Jan 25, 2007 7:55 pm
    http://crfsonly.com/forum/garage.php?mo ... age_id=961
    Many use the Scotts w/ the BRP SUB mount.
    '06 CRF250X / '05 VTX1300C / '03 XR70 / '01 Yamaha T-TR125L / '77 Peugeot 103SP
    '07 Blood Hound - dumb! / '02 mutt - smart! / '12 Goldendoodle - smarter!!
    Killaz
    by Killaz » Thu Jan 25, 2007 8:25 pm
    Here is a good thread concerning some mount options for the Trailtech if you decide to go for the submount:
    http://crfsonly.com/forum/viewtopic.php ... tech+mount
    '05 CRF450X
    '03 YZ250
    Kilroy
    by Kilroy » Thu Jan 25, 2007 9:51 pm
    After much searching and contemplating, I just ordered the Scotts with SUB mount for my '06. Can't wait to put it on... I will use my stock bars on the Scotts Under Bar (SUB) mount by using a new set of split bushings put out by BRP for a 1 1/8th bar mount while using stock 7/8th's bars. The bushings act like a shim for stock bars. Click here to see the BRP site with the SUB mount options, I ordered kit "B" and the new bushing. You'll still be able to use your stock triple clamp TOP clamp with this configuration. I figure that when (not "if") I bend the stock Renthals, I will simply remove them and put a good set of High Bend Fatties on there like Z did. If you call BRP toll free, they will gladly answer any questions you may have about your personal setup. They were very helpful to me...
    I hope this helps. #-o
    BTW: Hey Z, where did you get those bar mounts, and what kind of knuckle busters are those? I'm in the market.
    _____ooO_( )_Ooo___________________________
    _____|_____|_____|_____|_____|_____|_____|__|
    ___|____|_____|_____|_____|_____|_____|____|
    _____|_KILROY_WAS_HERE_|____|_____|____|
    by Ernie Pezz » Thu Jan 25, 2007 9:57 pm
    I mounted my Trailtech between the clamps for the bars.
    by Smash » Fri Jan 26, 2007 12:42 am
    Ernie Pezz wrote:I mounted my Trailtech between the clamps for the bars.
    I copied Ernie on mine.
    Kilroy
    by Kilroy » Fri Jan 26, 2007 8:21 am
    Smash, (or others)
    Are the Pastrana FMX "ATV Race" bend the highest made in the Contur bend?
    If so, you must be a tall guy like me...
    I need a set of those!
    Kilroy
    by JAWS » Fri Jan 26, 2007 8:26 am
    Yep, they are the highest that Pro Taper offers.
    by Ernie Pezz » Fri Jan 26, 2007 8:48 am
    What are you talking about? You're the one that told me how to mount it goofey!
    ="Smash
    What are you talking about? You're the one that told me how to mount it goof! :roll:
    Kilroy
    by Kilroy » Fri Jan 26, 2007 8:52 am
    I should listen to you "veterans" more often on bike ergo's.
    This aint my ole' KX500 anymore...
    by Smash » Fri Jan 26, 2007 10:23 am
    Ernie Pezz wrote:
    ="Smash
    LOL, Ok I remembered talking to you about it, so I just figured I copied, haha. Someone else came up with this idea first....... Just can't remember who....
    And yes they are the tallest bar.
    coljam
    by coljam » Fri Jan 26, 2007 11:58 pm
    Z wrote:http://crfsonly.com/forum/garage.php?mode=view_gallery_item&type=garage_gallery&image_id=961
    What is that large opaque 'tubing' running parallel to the bars?
    coljam
    by coljam » Sat Jan 27, 2007 12:13 am
    okay ... let's see if I've been schooled.
    Basically I have 2 options:
    1. Submount the damper - this will effectively raise my bar height 25mm, but I can still use my stock bars.
    2. Bolt on top of bars -- this will keep my ride height as is, but because the stock bars need the cross member for stability, I would have to replace them with bars that do not require the cross-member.
    Sound like I'm starting to get it?
    whoya
    by whoya » Sat Jan 27, 2007 12:23 am
    So I looked at using the existing triple clamp mounting tabs for the stock odometer. I cut a strip of mild steel from some scrap sheet metal channel that I had from another project. I decided to make a rectangular "loop" at one end of the strip with a tab on the end of the loop so I could weld it closed. The offset let me center the Lynx relative to the bars even though the stock mounting tabs are off-center. I sized the "loop" to raise the mounting position to exactly where I wanted it while keeping the Lynx below the top of the number plate.
    Looks like Fat Boy made a custom mount
    01' WR250F mods and dollars added
