Any Idea's For a Quick fix???
    devistation
    by devistation » Tue Jan 23, 2007 12:00 pm
    Broken Idle Screw!!! :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
    Look's like a pretty cheap spring just crimped on!!!
    by Asmith » Tue Jan 23, 2007 12:15 pm
    Yeah, go to the dealer and tell them you've been a bad boy!!!
    Honda Part # 16028-MEB-671
    $ 12.72
    devistation
    by devistation » Tue Jan 23, 2007 12:18 pm
    Your the MAN!!!! Thanks dude!!!
    How about the install, Does it just Simply screw in??? Any washers or o-ring's to be concerned with???
    Thank Paul,
    Devin
    by Asmith » Tue Jan 23, 2007 12:20 pm
    I believe it attaches to the linkage under the black cover on the side of the carb. If you haven't done the AP mod with the o-rings, now would be a good time.
    by bocephus450x » Tue Jan 23, 2007 12:22 pm
    you can probably find a diagrahm on the service honda link thing AS posted
    devistation
    by devistation » Tue Jan 23, 2007 12:23 pm
    ~ wrote:I believe it attaches to the linkage under the black cover on the side of the carb. If you haven't done the AP mod with the o-rings, now would be a good time.
    Do they Sell The o-rings separately?? I've been thinking about the boyesen cover too!!
    by Asmith » Tue Jan 23, 2007 12:30 pm
    Forget the AP cover, wastes a hundy like no other. Just do the o-ring mod. That's all it needs.
    PM me with your e-mail and I'll send you the whole mod on PDF. You can just buy the o-ring. I'll send you the size.
    by bocephus450x » Tue Jan 23, 2007 12:31 pm
    there has to be an o-ring store somewhere by you .... check the yellow pages.
    devistation
    by devistation » Tue Jan 23, 2007 12:32 pm
    ~ wrote:Forget the AP cover, wastes a hundy like no other. Just do the o-ring mod. That's all it needs.
    Sweet............... Thanks Again Paul!!!
    by Asmith » Tue Jan 23, 2007 12:39 pm
    E-mailed to you.
    The two O-Rings used in the AP mod are sized as follows:
    Small O-Ring
    W=1/16" ID=1/4" OD=3/8"
    Large O-Ring
    W=3/32" ID=1/4" OD=7/16"
  • DaveX
    by DaveX » Wed Jan 24, 2007 8:29 am
    Those pics of the idle screw look just like mine.
    I bet it took a lot of turns to adjust the idle a small amount, I never understood why each turn of the screw didn't adjust the idle until it twisted off :(
    Dave
    05 450x
    Acerbis Rally II Hand Gaurds
    Flatland Rad Gaurds
    Applied Bar Clamps - black
    Pro Taper KX High Bars - black
    Pink wire mod / Applied Vent kit
    Fastway case saver
    JD kit 170/ red needle clip in middle
    Twin Air / air box mods
    Quickshot APC
    devistation
    by devistation » Wed Jan 24, 2007 8:36 am
    DaveX wrote:Those pics of the idle screw look just like mine.
    Dave
    Mine Would twist maybe a 1\4 of a turn before it adjusted!!!! The spring seems to be the weak link! I thinking of brazing a cable on it "OFG Style "instead!! I'll see if it'll work when i tear it apart today!!!
    whoya
    by whoya » Wed Jan 24, 2007 12:20 pm
    Dave
    I've noticed on my bike turning the idle screw appears not to be doing anything. My bike suffers from the "hanging idle" therefore I cant notice a difference until I put it in gear and release the clutch a bit to get rid of the hanging idle. somthing to do with the slow jet I think, frustrating as hell......
    Also a little lubrication on the carb end of that cable makes it much easier to turn!
    01' WR250F mods and dollars added
  • Mr Smith
    by Mr Smith » Wed Jan 24, 2007 12:26 pm
    bocephus450x wrote:there has to be an o-ring store somewhere by you .... check the yellow pages.
    Check with Nasa....Sorry...Couldnt help myself.
    nowazzu
    by nowazzu » Wed Jan 24, 2007 12:57 pm
    But it was funny....huh?
    -nowazzu-
    05' CRF450X
