Crashed Hard!! Now water in oil?
    Bamm Bamm
    by Bamm Bamm » Mon Dec 18, 2006 10:34 am
    I crashed pretty hard hillclimbing yesterday while tuning the stage 2 cam. I ended up getting thrown from the bike and it tipped over and ran for about 20-30seconds upside down before I could get back to it. Now it leaked oil allover the motor of course.. I had to ride it back up the hill and back to the truck. When I got there was barely any oils in the case .. The tranny was at perfect level. SO I drained the rest of the oil out of the motor and filled it back to spec with new oil. and rode it for an hour or so.. When i got home i changed it again and the filter also(didn't have one with me in the tool box)..and there was still a lil water in there and it still looked a bit milky. at least 50% better than before though.. Now should I be worried? The bike is running like a raped ape right now. I have it really dialed and can pull a wheelie at any speed in any gear(just how I like it). But I'm just wondering if theres anything else I should check? DId I blow the water pump seal or ? Thanks
    Dan
    06' CRF450X-Pro-Circuit T-4, Hot Cams Stage2, Kibblewhite valves, JDJ kit 170 main, 48 pilot, K&N A/F, PC- T-4, FMF powerbomb,R&D fuel screw, Ziptye float bowl, lots of Carbon fiber, 14T-51T, Black Plastics, mirror polished frame(now dull)
  • Mr Smith
    by Mr Smith » Mon Dec 18, 2006 12:48 pm
    I had this car once that did awesome 50ft posi burn outs...Whipped anything in a drag race. The engine revved to the moon and back....Then it turned #7 rod bearing. :shock:
    Cant for the life of me think how you got water in your oil unless you blew a head or water pump gasget...That doesnt sound good.
    OLDFATGUY
    by OLDFATGUY » Mon Dec 18, 2006 1:01 pm
    Is your radiator low? are you losing coolant? Could you have gotten water in the motor on a previous ride, and maybe just now noticing it? If you have coolant in the oil, it should be going down. OFG
    Bamm Bamm
    by Bamm Bamm » Mon Dec 18, 2006 2:15 pm
    the coolant actually seems to be right where I normally run it thats the strange thing???? I'm wondering maybe if what happened is that maybe it isn;'t actually water causing the nasty looking oil and maybe some how oil from the clutch side came over??? Wait nah that wouldn't be since the clutch oil was amazing clean and not jacked up looking for once?? I wonder if something was wearing inside due to lack lubrication since the oil was bearing even registering on the dipstick when I checked it originally...??? I have a feeling I'm going to pull it apart a bit tonight and check the looks of the top end out at least.. LMK if there's anything else I should check. I think I'll get my compression tester back from my buddy and check that also.. It was at 58 earlier..
    Dan
    ~R.Dawg
    by ~R.Dawg » Mon Dec 18, 2006 7:00 pm
    What about gas in the oil?
    When in doubt, hit the gas!!
    dirty mike
    by dirty mike » Mon Dec 18, 2006 8:30 pm
    could it be assembly lube you used putting in the new cam? since you coolant level seems ok. Just a thought
    06 crf450x
    e2 pipe
    flatland rad guards
    flatland skid plate
    07 150r expert
  • Mr Smith
    by Mr Smith » Tue Dec 19, 2006 7:39 am
    dirty mike wrote:could it be assembly lube you used putting in the new cam? since you coolant level seems ok. Just a thought
    Good call...Most lubes of that type are Lithium based and will cause a milky discoloration in the oil.
    Bamm Bamm
    by Bamm Bamm » Tue Dec 19, 2006 9:07 am
    (Assembly Lube)....
    Boy I was just thinking that last night.=) I think you might be right.. I hope you are!!! I'm going to go back and hit up Carnegie in a few hours after it warms up a little bit and see how it goes it ran great after and my jetting and everything are finally about spot on=) This bike is stupid fast now=) I'll drain it out again when I get home and hopefully all will be good.. Havea great day guys. I'm loading up the bike in a second=)
    OLDFATGUY
    by OLDFATGUY » Tue Dec 19, 2006 3:15 pm
    Makes sense since your coolant level is not dropping. Problem solved! OFG
    Bamm Bamm
    by Bamm Bamm » Wed Dec 20, 2006 10:17 am
    I went riding yesterday I had so much christmas shopping to do though I wasn't able to get the oil changed I rode for about 3 hours I Did notice a oil leak somewhere towards the top of the motor ot much but I'll going to pull the tank tonight or tommorow night for further inspection.Man the bike was running great though
    Dan
    Bamm Bamm
    by Bamm Bamm » Fri Dec 22, 2006 12:57 pm
    So it's running damned near perfect I think the problem is solved it seems like it might still be leaking some oil from the top of the motor somewhere best I can tell is it's from one of four places
    1. valve cover gasket
    2. might've creaped up the valve cover bolts(there seems to be a small puddle of oil in the right front one)
    3. out the breather hole in the head next to my smog pump blockoff plate.
    4. out the exhaust flange??(I think it just puddled there though and hopefully that isn't the case)
    So I'm going to actually degrease it sunday morning and then for a bit of a ride if I can talk my wife into letting me out of the house. Maybe I'll just go to the motocross track and bring her to film=) and then see where were at.
    Thanks again everyone I appreciate all your replys
    cheezeburger
    by cheezeburger » Fri Dec 22, 2006 5:08 pm
    drain it bb and keep an eye on it. If you change your oil a couple of times and the milky oil doesn't come back, I think you are safe.
    if it comes back, you got problems
    Cheezeburger
    I'm whats left, I'm whats right
    I'm the enemy - So who are you?
    Bamm Bamm
    by Bamm Bamm » Thu Dec 28, 2006 8:41 am
    Well Luckily all seems to be good now.. THANK goodness!!! I'm off today and heading to Carnegie soon=)
