Question for those who have/have not had valve problems
    by nminus1 » Fri Jan 19, 2007 8:11 am
    palmrider230 wrote:Did I miss something here?Pauls got Hanks
    picture,Hanks got Pauls picture,Pauls in water next to
    dry land,Hanks on dry land next to water.Is this some
    kind of wacked out conspiracy?Are you guys sending us
    subliminal messages?And whats up with all these
    UFO's...
    Ernie, its OK just take a deep drag...hold it....hold it...now exhale. Hey who's wants a pizza?
    Roady
    Re: Question for those who have/have not had valve problems
    by Roady » Fri Jan 19, 2007 1:40 pm
    PhilM wrote:First off, don't take this as a slam. I am on track with figuring out why some bikes have problems and some do not. 250x guys and gals, please answer as well.
    For those that have not or have not had problems:
    1. What oil did you use? Synthetic or organic or a blend? Honda HP4M and HP Trans red bottle
    2. Do you still have the smog pump hooked up? no
    3. How often did you change the oil? after every trip, average 150 miles; same with air filter
    4. What gas did you run? Pump gas and what octane? If race gas, what motor octane and specific gravity was it? Unleaded or leaded. 91 pump
    5. When you have the valves replaced, did you replace the valve guides and stem seals? If so, with what? Are you seeing deposits on the valve base after the replacement. in the shop for 3rd valve adjust now at 2970 miles and it required maximum shim possible .. had them keep it for rebuild.
    6. What is your weight? How much do you feel you added or subtracted from your bike? 180 without gear; added weight with protection, but lost some with a lighter pipe .... probably added a few pounds
    7. Is your gearing stock? If not, what was the tooth count? yes
    8. Do you run a stock size rear tire? If not what size? Did it grip better than the stock tire? yes
    Thanks for your input.
    Waited until the last minute last Friday to do my maintenance before going to Baja Saturday morning and she wouldn't start. I pulled the tank and seat and took it to a riding buddy who runs my local honda shops service for the valve adjust. Just got the news today after going in to pick it up that I need to do the top end. 2970 miles with meticulous maintenance (don't know the hours) except for valve adjustments. I had them adjusted at 100 miles, again at 1554 miles with a minimal adjustment (don't remember exactly) and now at 2970. I am disappointed in having to shell out the bucks, but not in the bike. True, I never had this issue with 2 strokes, but I switched realizing the price of admission.
    Kind of funny that some of you never even check the valves and I catch crap from my buddies for being to lax on them.
    It is a good day to ride
  • Dust Devil
    by Dust Devil » Fri Jan 19, 2007 1:55 pm
    I wont be laughiong when the same thing happenes to me, that really sucks Chris.......you going to buy a new bike for baja :twisted: :twisted: :twisted:
    SO.....whats it going to be for the rebuild??? Valve type...ect
    You going to do a piston and rings at the same time (I would)
    Roady
    by Roady » Fri Jan 19, 2007 7:46 pm
    X has been great in Baja, I'll be keeping it :). Yes on the whole top end, and I am not sure yet about what all will be required or what type. Kibblewhites are what I always seem to hear good things about. My buddy at OCH said he wants to do a little research before giving me his reccomendation. Fortunately I have a lot of trust in him so at least I am not concerned about getting took maliciously, but I think the invoice is still gonna hurt...
    Missed riding the weekend before last due to A1, last weekend due to this issue and still won't have it back by next weekend, then A3 ..... hope I don't get the DT's
    by [email protected] » Sun Jan 21, 2007 9:23 am
    I wonder how an 07 R head would do on an X ? After all, it's got the two X sized smaller exhaust valves,and wouldn't be near as radical as those ProCircuit heads you ran.
    Either with a stock X cam or an R one it might be a great combination. If I had an X still and it was time I'd consider it . What do you think Chris ?
    This 07R has such a fun low to mid,you can dial on the power a fraction at a time with no big "bang". Doug
  • JD
    by JD » Sun Jan 21, 2007 10:06 pm
    1. What oil did you use? Synthetic or organic or a blend? (Reg 10w-40, Castrol-GTX)
    2. Do you still have the smog pump hooked up? (no)
    3. How often did you change the oil? (every 500 miles/filter changed too)
    4. What gas did you run? Pump gas and what octane? If race gas, what motor octane and specific gravity was it? Unleaded or leaded. (unleaded, any brand, 89-91)
    5. When you have the valves replaced, did you replace the valve guides and stem seals? If so, with what? Are you seeing deposits on the valve base after the replacement. (no adjustments)
    6. What is your weight? How much do you feel you added or subtracted from your bike? (240 lbs+)
    7. Is your gearing stock? If not, what was the tooth count? (stock)
    8. Do you run a stock size rear tire? If not what size? Did it grip better than the stock tire? (Maxxis IT-stock size)
    I have about 2200 miles on the bike (2005 450X) now. Bought in Sept 2005. I ride between 1,500-9,000ft., 35-100 degree weather, easy and hard riding, hill climbing, hard and soft terrain, low dust to very dusty conditions, etc. I also clean the air filter (K&N) after every 2nd or 3rd ride, depending on conditions
