by JAWS » Tue Jan 16, 2007 4:45 pm
Then go with some of the other suggestions in this thread. Make sure the throttle is not rubbing the bar end. Loosen it and pull it out just a bit, retighten and try it. Clean and lube your throttle. If you had your tank off, then make sure the cable isn't kinked somehwhere. Lube the cable. Don't use WD40, use a good cable lube.
