it is a oem cable and it doesn't work with the bike off it will still be engaged when I have the lever pulled and the pushrod is in but I'm not sure about the actuator arm I didn't pull it out when I did the clutch I just took the baskets out and changed the bearing and the thrust washer along with the new baskets and clutchHave you used a OEM clutch cable or an after market one?
Sometimes they are slightly too long and you run out of adjustment.
Does the clutch work normally with engine off - can you push the bike?
When you had the clutch cover off did the actuator arm look ok as in not worn or damaged?
Is the pushrod installed?
i can feel some play in the actuator arm when i took the cable off i can email you some pictures of the arm along with the pushrod and thrust washer i cant add them for some reasonWell if arm is worn or bent it can't move the pushrod sufficiently to disengage.
If that appears OK then the height of the clutch stack maybe slightly lower.
Try disconnecting cable and see how much free travel the arm has before hit pushrod. The clearance is probably only 10 or 20 thou at the pushrod.
If it takes up most of travel before hitting pushrod then either the arm is bent or there is something wrong inside.
I’m not sure which bearings you are referring to but the needle bearing that the clutch baskets are on I replaced with the baskets and the bearing on the clutch lifter I did not replaceHow are the ends of the lifter rod?
The only worn part I can see is lifter arm, on the bearing surfaces and where it pushes the rod.
With the arm in the case how much slop does it have in the bearings?
I’m not sure of the part numbers but I got oem baskets and then a Hinson clutch replacement that was for the year and model I had ordered them from a dealership and put them in and the clutch worked normally how it always had until the cable snapped once the cable snapped it just never worked after that the bike was off when it snapped and in neutral so im not sure what would of caused other things to break and sorry about not responding in awhile I was out of the country and didn’t have service where I wasTalking about the lifter arm. Is it galled like it looks in the photo?
How worn is is where the pushrod sits?
I think It was around 2011 that judder springs were installed in the pack.
I believe they could be replaced by additional plates.
I wonder if the stack is to high due to mismatch of parts and can't disengage.
Do you know which part numbers went into the clutch rebuild. Was it factory baskets etc.
the adjustment at the clutch lever is maxed out but it doesnt have enough adjustment to dissengage the clutch but the old clutch and baskets were pretty bad so i was thinking i probably need the pushrod, actuator arm, and thrust washerNot a problem, I don't get to look every day either.
So if it was working after the clutch replacement and you have only had the problem since replacing the cable it has to be and adjustment issue.
Is there a coarse adjustment at the clutch end?
Maybe the fine adjustment at handle bar is just running out.
You did receive the correct cable for your year - only other thing I can think of.
