CRF70 2006 fouling plugs rapidly
Posted: Sun Sep 05, 2021 9:42 pm
Hi guys,
I recently recovered a 2006 CRF70 that hasn't ran in about 10 years. The bike is stock. I changed the oil, air filter, and spark plug. I had the local honda motorsports dealer do a carb clean on it in an ultra sonic. They also rejetted it to stock, rebuilt the orings/float and set the adjustments to stock.
I'm noticing that the bike is still fouling brand new plugs after only a few minutes of riding. The plug is covered in dry black soot every time I pop one in. Sometimes very minimal puffs of black smoke out the exhaust. With a new plug the bike will run fine for about 5 minutes, and they start to bog down and struggle to run.
Compression test tops out at 150 PSI with WOT and takes about 10-13 kicks to get there.
Dry soot fouled plugs tells me carb issues.. but the carb should be fine after the dealer dialed it in to stock. Where else should I be looking?
Thanks all for any help
