CRF250R Clutch Pressure Plate Issue
  • NVUK
    by NVUK » Fri Nov 27, 2020 10:43 pm
    Hi there,
    I recently purchased a 2014 CRF250R and noticed the clutch was stiff and rough to the pull. I checked the clutch and noticed when I pulled the clutch in the clutch cover plate lifted unevenly and then noticed the clutch basket was grooved up bad. So I put in a new basket, plates and spring. However the clutch plate cover still lifts unevenly and it still feels stiff and rough to pull on the lever.
    So I put it back together and it seems to ride fine, but it's now bugging me having a stiff clutch and I would like to fix this issue. I found out later that the Judder spring had been removed too, not sure if this would make a difference? Anyway I ordered one of those and the clutch pull lever that on the bottom of the clutch cable and goes into the left side of the engine block then pushes the clutch rod, as I heard that can get worn and make for a stiff pull. But would that be the cause of the clutch plate cover lifting unevenly or should I get a new clutch lifter and bearings?
    Thanks!
    NV
