2008 crf250r not starting
  • Sieberg20
    by Sieberg20 » Mon Aug 05, 2019 4:01 pm
    Hi, I'm hoping someone can help shed some light on my situation. I just put rings in my bike and I went to start it, but i couldn't get it to fire, so i check the timing in all the locations and its spot on. So then i sprayed carb cleaner down its throat to act as starter fluid beings I don't have any. It still didn't start so I replaced the spark plug with a brand new one from NGK and and it still doesn't fire or pop at all. I am running 91 octane gas. Can anyone help me out. I don't want to take it to a professional, I don't have the money for that.
    Re: 2008 crf250r not starting
    by JimDirt » Tue Aug 06, 2019 8:42 am
    Can you give a detailed description of what you did replace/adjust , such as valves etc ?? , is it possible you took the cam tower off , and pulled the buckets and put shims in the wrong location , so its holding a valve open ??
    Need more info to help diagnose :-k
  • Sieberg20
    by Sieberg20 » Tue Aug 06, 2019 10:20 am
    I only pulled one bucket off and put it back exactly like I had it, the top caps for the cam came off the cam came out, really nothing with the valves was touched, I attempted to get the flywheel off the put the timing chain on the lower sprocket, that's about all the was touch besides the piston
    by JimDirt » Tue Aug 06, 2019 10:34 am
    What do you mean you "attempted" to get the flywheel off ??? , do you have the correct puller ??? and if so did you install it correctly , as you can't tighten the cap down all the way , you can damage the brass end on the crank , and you will lose oiling to the engine 8-[
    As far as the bucket goes , the shims can stick in the bucket and lift out of the top of the valve spring retainer , if that happens it can slide around , and not go down into where it needs to be , causing a valve to stick open , are you checking the valve lash after installing the tower ?? , you can do so on the bench with the head off , just align the mark on the sprocket with the mark on the tower and check , this will eliminate a valve sticking open as the issue ...... basically , if you have the timing correct , FRESH gas , your air filter connected , your header/muffler on and tight and you have spark ,and fuel to the plug , the bike should run
    Have you tried pulling the plug , dipping the electrode tip in gas and reinstalling (dip it all the way till the threads are in the gas) , then try to fire it and see if it pops or fires ???
  • Sieberg20
    by Sieberg20 » Tue Aug 06, 2019 3:51 pm
    I didn't actually get the flywheel off, so it should be in the same place. I know all the spacers on the valves are in the right place cause I checked them when I got put together. But I will have to try dipping the plug in some gas., and the gas in the bike is a few weeks old.
    Thank you for all you help
    by JimDirt » Tue Aug 06, 2019 8:58 pm
    OK , Try the gas and report back ...... this should help determine if it is fuel related or ignition
