2008 CRF No spark.
  • MLRBroc
    2008 CRF No spark.
    by MLRBroc » Thu Mar 08, 2018 11:19 pm
    I’m sure this has been beat to death so sorry for the revive. Also new here so hello all!
    My 2008 has no spark stator tests perfectly in spec. Coil primary resistance was more than spec so got a new oem coil and put it on still no spark. On another note my online manual will no longer load so anyone w a pdf that would be much appreciated.
    When connecting the spade wire to the new coil it did spark pretty heavy but still nothing to the plug at all. Any help would be great!
    Thanks,
    Broc
    Re: 2008 CRF No spark.
    by JimDirt » Fri Mar 09, 2018 3:10 pm
    Before we go any further , which model specifically is it ?? 450R , 250R ,450X ,250X , CRF230 , CRF150R/F, etc , ????
    All have different specs and troubleshooting procedures , and ignition and/or charging systems vary greatly per model , so specifics to the exact model is very important ..... 8-[ :?
  • MLRBroc
    by MLRBroc » Sun Mar 11, 2018 6:22 pm
    Not sure how I missed that sorry! It’s an 08 CRF450R. Only thing that tested bad resistance wise was the coil replaced it and still no spark I’m trying to find out if one of my meter can do peak voltage test on the stator. That’s the only test I haven’t done. I was going to pull continuity through the harness but with it being fixed and not plug in style at the cdi. I can only pin test and I’d rather not poke holes in the harness as this will be an xc bike.
    Thanks,
    Broc
