by Jtheiral » Tue Nov 17, 2015 7:46 pm
Thanks Harkon, I had to read more about thermal conductivity to see just how much a difference those numbers are.
While I was researching, I came across a forum that offered a little more clarification about Evans.
I personally don't see how Engine Ice coolant will allow an engine to run any cooler than Honda HP coolant or any other name brand coolant for that matter. I’m sure Engine Ice is a fine product, but so is Honda HP, Dex-Cool, etc, and most are a lot less expensive than Engine Ice. Just make sure you use a non-silicate anti-freeze in your bike because the silicates can cause problems with your seals. Pure water with a surfactant like Redline Water Wetter will cool better than any EG or PG based coolant, but you'll have to change it regularly to keep your system clean and to minimize corrosion.
If you’re racing certain events, then a product like Engine Ice, Evans NPG or pure water with a surfactant are about your only choices for legal coolants. Anytime water is used in a cooling system as with most coolants, the water in the coolant will boil at a temperature related to its system pressure. For instance, if your bike has a 1.8 bar radiator cap on it, this means your cooling system is pressurized to 53.154 inHg and you’re boiling point will be 255° F. You can increase your boiling point by using a higher pressure radiator cap, but that may not be a wise choice as your cooling system may not be able to handle that type of pressure.
The coolant from Evans is unique because it’s a waterless coolant (all propylene glycol instead of a PG/H2O mix) unlike anything else, but it has its own set of issues such as viscosity, flow rate, etc, so it may not be the best choice for some applications. On the flip side since Evans is a waterless coolant, your cooling system won’t suffer from the chemical corrosion issues from chlorides, sulfate and hardness of water that shorten the corrosion fighting ability of some water based coolants and you can keep it in your system for the life of your bike. Since it contains no water, its boiling point is much higher at 370° F, but a high boiling point doesn’t necessarily mean your engine will get that hot. Running an engine hotter isn’t necessarily a bad thing and boiling over doesn’t necessarily mean your engine is too hot at that point, but if there’s no coolant in your system due to a water based coolant boiling over, then your internal engine temperature will climb to dangerous levels much more quickly than if you had a coolant with a higher boiling point in your system to conduct the heat. Evans won’t cool your engine as well as pure water in the cooling system (just look at the specs above), but it will continue to work well past the boiling point of other coolants ‘IF’ the coolant temperature gets to that point.
There’s no perfect coolant for dirt bikes, but it’s nice we have different choices to meet different needs. Posted by Qadsan Apr, 2003. Thumper Talk
~John
2007 TRX 250ex
2004 CRF 250X
2000 VFR
