by 1kayaker » Thu May 14, 2015 10:33 am
Its the 450x. I have since figured it out that I had to remove the brake pedal lever. However when I unscrewed it using the hex tool it was a little sluggish. I figured that it must just be sticky, however to my surprise, when the pedal came all the way out, there was metal shavings on the ground. The screw went back in just fine, but I"m thinking there must have been a cotter pin or something on the inside of the frame where the end of the bolt was exposed that I must have screwed up…. Can you confirm?
